SPI port init for Bascom
2004-12-02 by John Allen
Hi Gang..!! Does anyone have any example Bascom code demoing the proper init and use of the hardware based SPI. I have the OLIEMEX MT128 demo board and ISP dongle as well, to connect to Bascom. I downloaded the PDF scat's and carefully wired up an add-on board to carry the signals from the connectors. I used a carrer board from Sparkfun Electronics to get the 8 pin LAP package of the Atmel AT25P1024C Flash SPI chip large enough to mount on a normal 100 center proto board. For the Atmega 128, MI is pin 13 PB3, MO is pin 12 PB2, SCK is pin 11 PB1 and SS is pin 10 PB0. I double checked the wiring to the slave Atmel chip. I am using a scope to view the control pins. Tests show that the firmware is not properly generating the SS signal or SCK signal. They just stay high. I have connected a jumper clip to ground and have touched it to the MI pin during the test and it does change the input data returned from Hex FF to 00. So I think the internal SPI routines are doing sonething, but the other pins are just not initing correctly... Before I got the MT128 board, I also had the Atmel "Butterfly" Demo board and have used the butterfly carrerr board to construct the same type of testbed. I will let ya know if Bascom works with the SPI on the ATmega 169 Demo Board. I tried to control the SS pim manually also... Thanks for any help...!!! Testfile follows...... 'first test program for ATmega-128 core... (started 11-22-04) ' started SPI testing after bulding an assed-on board to hold the Atmel 25P1024C (12-02-04) '$sim 'Uncomment this line to get rid of delays during sim runs... 'this is the "Declareing" section Dim Byte_reg As Byte Dim Flash_status_byte As Byte Dim Hex_string As String * 4 Declare Sub Gfs 'this is the "init" section Config Portb = Output Config Portc = Output Config Lcdpin = Pin , Db4 = Portc.4 , Db5 = Portc.5 , Db6 = Portc.6 , Db7 = Portc.7 , E = Portc.2 , Rs = Portc.0 Config Spi = Hard , Master = Yes , Polarity = High , Phase = 1 , Clockrate = 4 , Noss = 0 Spiinit Initlcd '[now init the clock] Config Date = Mdy , Separator = / ' ANSI-Format Config Clock = Soft Date$ = "11/30/04" Time$ = "12:00:00" Enable Interrupts 'start of main program section... Cursor Off Do Cls Lcd "ATmega 128 MCU" Lowerline Lcd "Evaluation Test" Wait 1 Cls Byte_reg = 0 Do Call Gfs Home Lcd "Loopcount >" Lcd Byte_reg Lowerline Lcd "Status >" Lcd Hex(flash_status_byte) Lcd " " Lcd Flash_status_byte Incr Byte_reg Waitms 250 Loop Until Byte_reg = 10 Cls Lcd "Date: " ; Date$ Lowerline Lcd "Time: " ; Time$ Waitms 250 Loop Gfs: 'get flash chip status Flash_status_byte = 05 'read the status reg command for Atmel AT25P1024P Flash chip 'Reset Portb.0 Spiout Flash_status_byte , 1 Spiin Flash_status_byte , 1 'Set Portb.0 Return End
