AVR-Chat
USART string reception
2004-11-20 by Ian Drennan
I am new to AVR and want to receive and store a string of 10 bytes transmitted from the PC. Each sequentially received byte needs to be stored into a variable(1 of 10) in SRAM for later use. I am using the USART in asynchronous mode on the mega8 and want to use the USART Receive Complete Interrupt for each received byte. I have done a search but have not found a suitable method to do this. What is the slick way to do this, and do I need to send an ack for each byte received to pace the transmission from the PC?
Many thanks
Ian
Re: USART string reception
2004-11-20 by Don Kinzer
--- In AVR-Chat@yahoogroups.com, "Ian Drennan" <ianid@s...> wrote:
> I [...] want to receive and store a string of 10 bytes transmitted
from the PC. [...] I am using the USART in asynchronous mode on the
received byte. [...] do I need to send an ack for each byte received
No, it's simpler than that.  You just need to enable the interrupt
and write an interrupt handler to retrieve the received character.
Unless you're using "flow control" (which requires additional
circuitry and logic) the PC will simply send the characters one after
the other whether or not you retrieve them properly.
If you want to, you could design the two ends of the comm channel to
implement acknowledgement.  You could write special code on the PC
end to wait for the acknowledgement before the next character is
sent.  This is probably not necessary unless you have special
circumstances which increase the probability of character loss.
Re: [AVR-Chat] Re: USART string reception
2004-11-21 by Ian Drennan
To: <AVR-Chat@yahoogroups.com>
Sent: Saturday, November 20, 2004 10:45 PM
Subject: [AVR-Chat] Re: USART string reception
Don
Thanks for your reply and comments. I managed to come up with a interrupt
handler which seems to work fine. I echoed the string back to the PC just to
see that all was intact as intended. This is using the R0 to R9 for
temporary storage. My next attempt will be to store the bytes directly into
SRAM using the Y pointer.
regards
Ian
Here is my sorting  code just for interest:
sort_bytes: ;sorts a string of sequential bytes and allocates each byte to a
specific register
 inc byte_count
 cpi byte_count, 0
 breq byte0
 cpi byte_count, 1
 breq byte1
 cpi byte_count, 2
 breq byte2
 cpi byte_count, 3
 breq byte3
 cpi byte_count, 4
 breq byte4
 cpi byte_count, 5
 breq byte5
 cpi byte_count, 6
 breq byte6
 cpi byte_count, 7
 breq byte7
 cpi byte_count, 8
 breq byte8
 cpi byte_count, 9
 breq byte9
byte0: mov r0, temp
ret
byte1: mov r1, temp
 ret
byte2: mov r2, temp
 ret
byte3: mov r3, temp
 ret
byte4:  mov r4, temp
 ret
byte5:  mov r5, temp
 ret
byte6:  mov r6, temp
 ret
byte7:  mov r7, temp
 ret
byte8:  mov r8, temp
 ret
byte9:  mov r9, temp
 ser byte_count ;reset the byte_count to 255 so next increment will roll it
over to zero
 rcall  echo_all
 ret
Echo_all:
 mov temp,r0
 rcall transmit
 mov temp,r1
 rcall transmit
 mov temp,r2
 rcall transmit
 mov temp,r3
 rcall transmit
 mov temp,r4
 rcall transmit
 mov temp,r5
 rcall transmit
 mov temp,r6
 rcall transmit
 mov temp,r7
 rcall transmit
 mov temp,r8
 rcall transmit
 mov temp,r9
 rcall transmit
 ret
