AVR-Chat
Re: [AVR-Chat] Simple UART Code
2004-10-06 by JChavez@soboce.com
It depends on what AVR you are using however this shoul help..
void RS232_init(void)
   outp(0x18, UCR);
   //outp((char)UBR, UBRR);
   outp(8, UBRR);       // 12=38400 8=57600 3=115200
   sbi(USR, TXC);       // UART Trnsmt complete (clear TXC flag but logical
1)
   cbi(DDRD, PD0);      // RXD (UART input line)
   sbi(DDRD, PD1);      // TXD (UART ouput line)
uint8_t cin(void)
   loop_until_bit_is_set(USR,RXC);
   return(inp(UDR ));
void cout(uint8_t a)
   outp(a, UDR);
   loop_until_bit_is_set(USR,TXC);
1)
then  in main ..
    cout((cin());
Hope this helps..
Javier
Re: Simple UART Code
2004-10-08 by upand_at_them
For transmit, does checking TXC instead of UDRE limit the max
transmit speed?  And what is the lag between writing to UDR and it
getting put into the transmit shift register?
Mike
>    outp(0x18, UCR);
logical
> 1)
> uint8_t cin(void)
>    return(inp(UDR ));
>    outp(a, UDR);
logical
> 1)
> then  in main ..
>     cout((cin());
> Hope this helps..
> Javier
Re: [AVR-Chat] Re: Simple UART Code
2004-10-08 by Dave VanHorn
>transmit speed?
Well, you can't shove chars in faster than they go out..
Essentially zero.
I've never measured it, but it's not much.
Obviously.
But I noticed the two stage pipeline.  and if you wait until
something comes out the end of the pipe before you put anything in it
cuts the speed down.  I just didn't know the lag between data
register and transmit register.  If it's just a clock cycle or two,
then you're right, it won't matter.
MK
> >transmit speed?
> Essentially zero.
ICCAVR Vs STK-500
2004-10-09 by Dave VanHorn
Wierd.. I can erase the chip just fine, and it DOES erase, but it won't program!
Here's the output, that shows that it does see the STK-500.
STK500 v 1.51 (C) 2000-2004 Atmel Corp.
Scanning port.. com4 STK500 detected!
Done.
informational - project has no EEPROM file
Programming and Verifying FLASH...
"C:\Program Files\Atmel\AVR Tools\STK500\Stk500.exe" -z -dAT90S8515 -ccom4  -e -pf -vf -ifE:\Software\Cstuff\LedThing\ledthing.hex
Scanning port.. com4 Port not present or in use by another application
STK500 not detected!Done: there are error(s). Exit code: 1
Cannot program or verify Flash
ISP programming done.
So it isn't succeding, but I don't see why..
Ideas?
Re: [AVR-Chat] ICCAVR Vs STK-500
2004-10-09 by jay marante
is it possible to program the STK500 using just the ICCAVR?
Done.
Ideas?
Yahoo! Groups SponsorADVERTISEMENT
Yahoo! Groups Links
   To visit your group on the web, go to:
http://groups.yahoo.com/group/AVR-Chat/
AVR-Chat-unsubscribe@yahoogroups.com
Do you Yahoo!?
vote.yahoo.com - Register online to vote today!
2004-10-09 by ramachandra bhat
remove whatever s connected to the ports and try...........see that nothing else is working with it
Done.
Ideas?
Yahoo! Groups Links
Do you Yahoo!?
Yes.
u require AVRstudio link for prog STK500 using ICCAVR..........not possible without it
Yes.
Do you Yahoo!?
Yahoo! Mail Address AutoComplete - You start. We finish.
I checked, nothing else is running that would talk to the programmer.
I shut down ICCAVR and restarted, now it's different.. :-P
When I rebuild the project, in very rapid succession, I get a message that the .lst file has changed, and a box that says "cannot program or verify EEPROM".
In the message box, (where the compiler output happens) I get the COM4 port not present message...
When I OK the box about the .lst file changed, then the EEPROM box, it goes off and then programs the chip!
I have that, it's pointed into the studio4 directory and at STK500.exe
Resolved, sort of..
Works ok on COM1
On Com4, it is definitely flipping the bits to the chip, but something's not right.
I've used the same STK-500 through the same port with Studio, with no problems.
Possibly something in the command line it passes to STK500.exe, at least that's my guess.
So, up and running, but EVERYTHING wants COM1 and COM2!
2004-10-10 by MuRaT KaRaDeNiZ
For the UART and usual baudrates, this lag is
unimportant but I would like having a hardware buffer
for the SPI unit, and have additional flag indicating
byte move buffer to transmit shift register. Motorola
implements such feature in its micros.
Murat Karadeniz
http://www7.brinkster.com/mukas/
> out..
> Obviously.
> wait until
> put anything in it
> between data
> clock cycle or two,
> MK
> limit the max
> > >transmit speed?
> out..
> it
> > Essentially zero.
Do you Yahoo!?
http://promotions.yahoo.com/new_mail
Re: ICCAVR Vs STK-500
2004-10-11 by Sean Ryan
> Resolved, sort of..
> Works ok on COM1
no problems.
I get the same error..  Including on COM1 or 2..
It seems to have originated in an update to AVR studio..  (Maybe
4.09?)  I find myself using Avr Studio's built-in programmer to burn
my chips, or giving the project a fake eeprom file.. (Once it fails
to communicate the EEPROM, if successfull will program the Flash)
I've attached an example..  Here I've added a fake eeprom file so the
flash will burn.. Without the eep, it fails on burning the flash.
"g:\Program Files\Atmel\AVR Tools\STK500\Stk500.exe" -z -dATMega169 -
ccom3
Scanning port.. com3 STK500 detected!
Done.
Programming and Verifying EEPROM...
ools\STK500\Stk500.exe" -z -dATMega169 -ccom3  -e -pe -ve -
ieC:\CVSSource\AV
R\CIII\AnalogIO\AnalogIO.eep
Scanning port.. com3 Port not present or in use by another application
ools\STK500\Stk500.exe" -z -dATMega169 -ccom3  -pf -vf -ifIgntISO.hex
Reading FLASH input file.. OK
Setting device parameters, serial programming mode ..OK
Entering programming mode.. OK
Programming FLASH using block mode..       OK
Reading FLASH using block mode..       OK
FLASH contents is equal to file.. OK
Leaving programming mode.. OK
Done.
Re: [AVR-Chat] Re: ICCAVR Vs STK-500
2004-10-11 by Dave VanHorn
Well that's pretty wierd.. I'll give it a try.
