Strange problems
2004-09-24 by mikkohelin
I implemented a flash burner for AT29C256 using XMODEM protocol with 8515 and STK200. Xmodem (checksum) uses 128 byte page size while the Atmel flash eeprom use 64 byte page size. So I use for loop (~40000 iterations, null body) for delay after writing the data into flash. However, my program freezed in the second delay loop. It can't be because of TeraTerm Pro, it should wait the ACK byte for a second or so? Could it be a WDT issue? I used gcc-avr, and the code from xnutboot.c (converted to 8515). Also I called wdt_disable() in the beginning.
