AVR-Chat
Problem with Atmega128 reset line
2004-08-27 by Yang Wang
Hi all,
Can we connect the reset line and +5V line with a 1k pull-up
resistor, to keep the reset line high? Out of the 8 circuit boards
with the same schematics I am building, 6 of them work in this way,
while the other two do not. For these two problematic ones, the reset
line is always jumping between 2.1V and 4.7V, not stable at all.
I feel like this 1k pull-up resistor setup should work for keeping
the reset high, but I cannot find out why the reset line is not
stable when it is connecting to +5V by the 1k resistor. Or am I
wrong, and do I have to connect the reset line with +5V directly?
Thanks a lot!
Yang
RE: [AVR-Chat] Problem with Atmega128 reset line
2004-08-27 by Lasse Madsen
Hi Yang..
If you look at the ATm128 datasheet over the Reset line you will find no reason why the mentioned thing should occur…
A badly designed power supply comes to mind … try adding a large capacitor to your +5V and at least 100nF to Reset ..
Regards
Lasse Madsen
Sent
: 27. august 2004 20:25
To: AVR-Chat@yahoogroups.com
Subject: [AVR-Chat] Problem with Atmega128 reset line
Hi all,
Thanks a lot!
Yang
Re: [AVR-Chat] Problem with Atmega128 reset line
2004-08-28 by Brian Dean
Yes, that should be fine.  I normally use a 10K pull-up, but 1K should
work.  You don't usually want to to tie the line directly to 5V - if
you want to program the chip in-system, the programmer must pull the
reset line low, and it can't do that if you tie the line directly to
5V without a resistor in between.
-Brian
Brian Dean
http://www.bdmicro.com/
