AVR-Chat
which programmer ?
which programmer ?
2004-07-27 by Dave Mucha
Hi All,
I have been reviewing the archives to get an idea of a simple way to
program some chips.
As it is now, I am just getting started and an not looking for the
most universal, but the best cheap unit, even if it limits my chip
selections.
I'm hoping there is some simple programmer that can be assembeled by
the average parts bin we typically have.  (some scattered on the
bench, others still in boards yet to be sacrificed and others in
those neat little baggies from the suppliers)
As you probably know, I'm doing a little reading on the C language
and have considdered dabbling with FastAVR or Basicom as a way to get
things happening faster.
From the little that I could really understand about programmers,
there are serial, parallel and USB, with USB being rare.
Then there is ISP which is fine with me as I would rather make a
board for testing than to move chips around.
But to get started, I'm hoping to put together a simple board with a
uC a couple outputs and a couple inputs and a serial cable for use
with I2C or SPI as the case may be.
At this point, I don't need to worry about programming any other
chips like e-proms or the like.
Any suggestions ?
Dave
Re: which programmer ?
2004-07-27 by Don Kinzer
My recommendation is to get a STK500.  They're about $80 at DigiKey
(http://dkc3.digikey.com/PDF/T042/0294.pdf).  It supports a wide
variety of chips and serves as a simple test bed (lights, switches,
etc.).  Its ISP programmer can also be used to program your AVR in
its circuit simply by connecting a 6-conductor cable between the
STK500 and your board.
Another option is to build a simple serial programmer.  I have built
one that uses an AT90S2313 and supports the AVR-910 protocol.  Some
examples of this type may be found here:
http://www.serasidis.gr/circuits/avr_isp/avr_isp.htm
http://www.peg.si/electro/avrprog.html
I built the one using the 2313 and it works well.  However, the 910
protocol is slower (perhaps 5x) than that used by the STK500 so if
you're planning to program the larger devices this may be an issue.
The parallel interface is perhaps the simplest.  I have not built one
but I have read a lot about them.  The software most often mentioned
is PonyProg.  You can read about it and see the interface schematic
here:
http://www.lancos.com/prog.html
2004-07-27 by Graham Davies
--- In AVR-Chat@yahoogroups.com, "Dave Mucha" <dave_mucha@y...> wrote:
> ... simple way to program some chips.
> ... best cheap unit, even if it limits
> my chip selections ...
I get the impression that low cost is important to you, so the STK500
might not be the answer you're looking for. Even so, I think you
should consider getting a programmer ready-made rather than making
one yourself. This would avoid a chicken/egg problem if you find you
can't program your first actual circuit. The Atmel Web site lists
third-party tools. Or, take a look at AVR-PG1B here:
http://www.sparkfun.com/shop/index.php?shop=1&cart=57355&cat=4&
Graham.
Re: [AVR-Chat] Re: which programmer ?
2004-07-27 by David VanHorn
>here:
The BA1FB programmer is very nice, I use it a lot.
Other than that, it's an AVRISP, or STK-500
2004-07-28 by Sal Brisindi
Hi Dave,
Checkout http://www.futurlec.com/ATDevBoard.shtml
I bought my AT90S2313 developement board from them for $19.90 which
will allow you to connect a LCD display and other things to it. It
comes with a CD and cable. This will only flash the Atmel AT90S2313
but for the price it is well worth it.
Sal Brisindi
http://www.numitron.com
wrote:
> Hi All,
to
> program some chips.
> selections.
by
get
a
> Any suggestions ?
> Dave
RE: [AVR-Chat] which programmer ?
2004-07-28 by Larry Barello
What is your development environment?  That might make a big difference on
which programmer to use.  Avrdude, which comes with the WinAvr (GCC C
compiler) works with a variety of programmers including some "no parts" ones
like the SAMPLE programmer I supply with my ARC boards (www.barello.net/ARC)
You can see the schematic in the users guide.  If you want you can dispense
with the resistors and just use an old LPT cable, cut & the proper wires
brought out to your programming header.  Works great.  PC only.
Oh, yeah, the SAMPLE programmer is what BASCOM uses...  Pretty slick.  I
recommend it for getting started.  It makes stuff like serial I/O and LCD
and one wire stuff very easy.
Cheers!
Hi All,
program some chips.
selections.
Any suggestions ?
Dave
Yahoo! Groups Links
2004-07-28 by Dave Mucha
--- In AVR-Chat@yahoogroups.com, "Sal Brisindi" <tubeman59@y...>
wrote:
> Hi Dave,
> Regards,
> Sal Brisindi
Hi Sal,
Thanks !
Seems Fururlec has lots more than just a few boards.
I am not sure if they are kits or fully stuffed boards, but will find
out tomarrow.
They have a few controller boards, for the Atmel line, they offer
these boards.
ATMega Controller
AT89C52 Controller
Both seem to offer a great starting place as does the development
board.
Thanks for the link !
Dave
Re: [AVR-Chat] which programmer ?
2004-07-28 by Mike Murphree
> difference on
> parts" ones
> dispense
> wires
I finally retrieved my Xilinx parallel JTAG cable (DL5?) from work.  I
seem to recall that this cable worked with one of the available
packages.  Any suggestions on what software will work with it?
TIA,
Mike
> wrote:
> > Hi Dave,
which
AT90S2313
> > Regards,
> > Sal Brisindi
> Hi Sal,
> Thanks !
find
> out tomarrow.
> these boards.
> ATMega Controller
> AT89C52 Controller
> board.
> Dave
Hi Dave,
I do know the '2313' board is not a kit but fully assembled. Let me
know how make out.
Sal
2004-07-29 by Rodrigo Feher
Can STK500 program ATTiny11?
Rodrigo
2004-07-29 by David VanHorn
Out of circuit only,  the T11 is high voltage only.
