Re: [AN1x] Digest Number 1619
2005-09-19 by Albert Ibrahim
Jon, Thanks for the comprehensive reply... that was waaay helpful. Thank you, thank you!!!! I've looked at Unisyn and it does not support the an1x. I am reluctant to run OS9 on my machine especially with OMS because it tends to screw up my DP settings. But, then that was DP3 in OS9... I might just try that... Midiquest looks interesting certainly.. It's a little pricey though!! I might just bite the bullet and organize my patches on the An1x itself.... aL Message: 2 Date: Sun, 18 Sep 2005 13:48:36 -0700 (PDT)
From: Albert Ibrahim Subject: Re: AN1x Editor Librarian I would use the editor except I am running on a Mac with OSX. Anyone know of an editor or librarian in OSX that can allow me to have folders for organizational purposes? TIA aL > Message: 9 > Date: Sun, 18 Sep 2005 16:26:33 -0000 > From: "spaceanimals" > > Subject: librarian editor > > AN1X edit is an editor, not a librarian. Still, you > can open up several > banks of sounds, drag all your 128 favorite lead > sounds into an edit > session and save it as leads or pads or weird noise > or whatever. __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com ________________________________________________________________________ ________________________________________________________________________ Message: 3 Date: Mon, 19 Sep 2005 00:24:39 -0000 From: "Jon" Subject: Re: AN1x Editor Librarian --- In AN1x-list@yahoogroups.com, Albert Ibrahim wrote: > I would use the editor except I am running on a Mac > with OSX. Anyone know of an editor or librarian in OSX > that can allow me to have folders for organizational > purposes? > SoundQuest makes a commercial Editor/Librarian native to OS X and it supports the AN1x: MIDI Quest and MIDI Quest XL. A demo can be had here: http://www.squest.com/Macintosh/MidiQuest/MidiQuest-About.html The primary difference being XL will run from within your VST host application allowing you to control your AN1x as though it were a VSTi. I ran the demo for a short period, but found its performance to be lackluster - perhaps this was an anomaly or a bug in how MidiQuest communicated with my MT-4 - either way, I did not spend enough time with it to comment on it's organizational features of the Librarian features. Emagic made Sound Diver - another Editor/Librarian - which made it to a second beta release under OS X after the move to Apple, but AFAIK it is not presently available as a commercial product - I think SD in it's current state may only be available to licensed users of previous releases and possibly Logic Pro users. There is well established SD list here at Yahoo! Groups which you search for the latest news & rumors regarding SD. Again, I cannot comment on it's organizational features of the Librarian features. I believe Unisyn from MOTU might still be available for OS X, but I've no idea if it supports the AN1x: http://www.motu.com/products/software/unisyn/body.html/en and then there is JSynthLib - an Open Source Universal Synthesizer Patch Editor / Librarian written in the Java Language, but no AN1x support (yet? who konws...) http://www.jsynthlib.org/ With the advent of virtual instruments, the sad truth is that Editor/Librarians are simply not as much in demand as they use to be. As already mentioned in this threa, AN1xEdit is an Editor/Librarian, i.e., it can be used to both edit and store Voices and User Seq's, etc. from your AN1x, PLG150-AN and AN200. Although AN1xEdit is not a native OS X application - nor will it be - it runs perfectly well under Classic within OS X - just as it does under Mac OS 9. If you are running Panther, and probably Tiger too, and you have a USB MIDI Interface with native drivers for both OS 9 (Classic) and OS X you may install OMS 2.3.8 under Classic with the appropriate driver for your MIDI Interface and run AN1xEdit which will communicate as expected with your AN1x. Apple made a change to the API within Panther that allows direct communication to the hardware ports, i.e., USB ports, from within Classic - this was not permitted under Jaguar or earlier revisions of OS X. Even without establishing MIDI communications from within Classic, using AN1xEdit, the may be useful simply to convert the many banks of .AN1 format voices to .MID or .SYX which can be used in other applications. Feel free to post back with questions if you need assistance with this configuration. Somebody posted this tip to the list at the beginning of this year and I've used this configuration reliably ever since. As mentioned in a previous post - there are two readily available freeware bulk librarians. SysEx Librarian from http://www.snoize.com/SysExLibrarian/ MIDI Dump from http://perso.wanadoo.fr/mpergand/applis/midi_dump/en/midi_dump.html Neither has an advantage over AN1xEdit for sorting or organizing your AN1x Voices as they are Bulk Librarians - this means you will need to organize your voices on the AN1x proper. Yamaha included a Category Type which can be stored with each Voice as it is named, but there is no provision in either AN1xEdit, or the AN1x itself, from which to sort your Voices - this oversight again forces you to sort your voices manually. At the very least, you can recognize what type of Voice you are working with assuming the Category has been applied accurately. As Jimmy already mentioned, you can sort your Voices within AN1xEdit manually by using copy & paste to a second or third or fourth editing session - you simply click on the tabs at the top of each window to 'jump' between the sessions, the you save each indepent of each other named accordingly. I believe Ed wrote a program to sort Voices by name, but I don't know how, or if, he dealt with the Category Type field. You might care to glance at this doc: http://tinyurl.com/96mkt Don't know if he's willing, or if he has the time, to modify his program to sort on Category Type - it might not be possible, don't know either way. HTH Jon __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed]
