Midi-Clock-Messages from Xworks
2005-08-30 by atawoolf
Hi
Xworks 3.0 have 6 Midi Outs, but only the first slot of the Midi-Outs
is sending Midi-Clock messages, when i push start. Is that right ??
Because only 1 unit starts playing when i push start. I have 2 units
(AN200 and DR660) and both have his own Midi in/out over my USB Edirol
UM2. That unit you select under System/Options/Midi-Output in the first
slot of the 6 Midi Outputs, starts playing. Putting AN200 to slot-1
Midi-out1 and DR660 to slot-2 Midi-out2 , does not work. Than only the
AN200 will start, if you change the slots, only DR660 start, but not
together.
Is there a way to send Midi-Clock messages over the other 5 Midi Out
slots as only slot-1 ??? Thanx
