--- In AN1x-list@yahoogroups.com, "stephen bennett" <chaosstudios@h...> wrote:
> --- In AN1x-list@yahoogroups.com, "Jon" <jondl_2000@y...> wrote:
> > Are you running Panther (10.3.x) or Jaguar (10.2.x)? Have you
> tried SD under Classic?
> > Regards,
> > Jon
> Thanks for the replys guys
> I'm running Panther. No, I've not tried it under Classic. Is there
> a 'how to' anywhere?
We just discussed this recently on AN1x-list, if you check the archives from January you'll
find a post similar to this:
Start Classic.
Install OMS 2.3.8 (still available from the Opcode 'site amongst others). Make certain to
install the current drivers for your USB MIDI Interface - the installer should place them in
the Opcode folder within the System folder of your Classic install.
Configure a Studio Set-up doc in OMS with your normal configuration - use the Test
Studio function to check.
Install SD, configure to use OMS.
Good luck,
Jon
