Representin'
2000-07-13 by Elson Trinidad
2000-07-13 by Peter Korsten
> Here's another artist that uses a certain blue synth :)Interesting, as a mono synth ("mono" as in "not stereo"). It appears
> http://www.e-trinity.org/pix/lotus2000-elson1.jpg
> More at www.e-trinity.org - click on "images"Hmm, blue text on a black background... all time favourite, though
>Elson Trinidad shared with us:It's in mono because in most live applications, stereo is futile. But for a
>as if there's some outboard gear connected to it, right?
>> More at www.e-trinity.org - click on "images"Is that a diss?
>not mine.
>Er? What I mean is that you often see blue text on a black background,
> >not mine.
> Is that a diss?
2000-07-13 by Phil
"It's in mono because in most live applications, stereo is futile. But for a
song I had it connected to my Korg ER-1 drum machine to "gate" some string
pads, then I had to plug it back into the mixer. The ER-1 only has a mono
input, so that's why."
Two questions for Everybody:
1) If you're using a 'D'igital 'A'udio 'W'orkstation (ie computer multi-track hard disk recorder) for composing tracks, do you tend to record in mono? My thoughts are that with exception of 'pan', it's only the effects such as reverb, and chorus that give a 'stereo' effect. In which case this can be performed in the DAW with mono tracks - saving power and space over stereo recordings. Also, most mixers feature mostly mono inputs making it hard to accurately track the levels of EQ etc. of stereo sources. It seems that dealing with a mono source is a lot easier to work with???
2) What level do you normally set the output volume on your AN1x? I've always set it on full and hoped the headroom was sufficient enough not to clip. I've noticed that on some patches I'm actually getting extra (unwanted) distortion. Maybe I should re-save the patch with a lower volume-parameter setting so that it doesn't clip from the main volume. What do you people think about volume settings on musical instruments? Maybe the pre-amps on my AN1x are slowly deteriorating.
Cheers,
Phil
2000-07-13 by Edwards, Ed
>2) What level do you normally set the output volume on your AN1x? I'vealways set it on full >and hoped the headroom was sufficient enough not to
>volume-parameter setting so that it doesn't clip from the main volume. Whatdo you people think >about volume settings on musical instruments? Maybe the
