Re: [AN1x] clearing all voices...
2004-05-11 by James Acker
From: "nuskoolbreakz81" <nuskoolbreakz81@yahoo.com> > im just wondering if there is a way to clear all factory programs > from my AN1x? i want to program all my own patches for a breaks set > im working on. any help you could give me would be great. > cheers, > Jude You can set everything back to factory reset values as far as I know. Thereafter you could creat patches say, and always have the first letters be "J_" if you wanted to make sure you only use your own patches. Not sure what the point would be though...if you think about it, no matter what you are either going to have a really big set of boring (all the same) patches until you went in and edited them anyway...and anytime you edit you can always choose the same starting point. Another thing, are you using An1x Edit, the software MIDI interface from PC to the An1x? It would be easier if you were. Maybe if you told a little more about why you want to do it someone could give you some better advice. If it is just the urge to "start with a clean slate" then I think you would be doing a lot of work for little benefit. Eventually you build up a library of your favorites anyway, and if you DO have the An1x Edit and a PC hooked up, it is much easier to save, maintain libraries for different things (like one could have all setting for patches optimum for live performances, one library of pathes for direct in to recording devices, etc.). Hope this helps a little anyway. Jim
