Index last updated: 2026-03-31 13:41 UTC
clearing all voices...
2004-05-11 by nuskoolbreakz81
hey there,
im just wondering if there is a way to clear all factory programs
from my AN1x? i want to program all my own patches for a breaks set
im working on. any help you could give me would be great.
cheers,
Jude
Re: clearing all voices...
2004-05-11 by Jon
--- In AN1x-list@yahoogroups.com, "nuskoolbreakz81" <nuskoolbreakz81@y...>
wrote:
> hey there,
> cheers,
> Jude
There is no shortcut to Initialize all 128 Voices in the AN1x simultaenously - only one
Voice at a time. As mentioned in the previous reply - you might be able to perform
this task from AN1xEdit by loading an emply, default bank into the AN1x.
For details on how to perform the Voice Init from the AN1x, see page 97 of the
Owner's Manual. To summarize: Enter [130] from the keypad - press [YES/ENTER] -
reply [YES/ENTER] and "Type? 1-8" will display. Select the template Type[1-8] from
the keypad to proceed.
1= Normal, 2 = Bass, 3 = Brass, 4 = Strings, 5 = E. Piano, 6 = Organ, 7 = Sync, & 8 =
PWM There are a number of Voice Creation Examples onpages 101-108 I suggest you
try out if you're new to the principles of Subtractive Synthesis.
Jon
2004-05-12 by nuskoolbreakz81
Thanks for the info :)
will give it a go when i get home.
cheers,
jude
> wrote:
> > hey there,
programs
set
> > cheers,
> > Jude
able to perform
AN1x.
page 97 of the
[YES/ENTER] -
I suggest you
> Jon
2004-05-13 by christone@onetel.net.uk
The best way to do this is surely simply to dump the factory
voice set in via MIDI....?
2004-05-13 by nuskoolbreakz81
will this leave me with 128 empty voices? might try it
2004-05-13 by Jon
No, it will not.
You can either a) try and dump an empty, initialized bank of 128 Voice from
AN1xEdit, i.e., the default bank of initialized Voices or b) initialize each Voice
individually as needed or c) initialize a single voice on the AN1x, dump it to
AN1xEdit, Copy/Paste this single, initialized voice to all 128 programs withinin
AN1xEdit THEN dump the whole lot back into AN1xEdit.
To be quite honest, I fail to see the benefit to your programming effort of an AN1x
with 128 initialized Voices!?
Jon
