Ribbon stuck at lowest level
2003-10-09 by cernikj_98
I'm new to the An1x and the list. I just picked up an An1x and it
seems that once I touch the ribbon controller, whatever value it is
assigned to drops down to its lowest value as if my finger was still
on the ribbon at its lowest point. I know it can be set to relase to
the last touched position but it goes to the lowest no matter where i
leave off.
is this something anyone else has experienced? Is the ribbon bad?
Does anyone know if it a new ribbon controller can be purchased and
replaced?
Joe
Re: [AN1x] Ribbon stuck at lowest level
2003-10-09 by Bruce Wahler
Hi Joe,
>leave off.
>replaced?
Jimmy's right: This is a bug/feature of the AN1x. If you program the modulation matrix to use Ribbon X on all of your patches, you'll probably find that some of them latch at the last-touched point, while others drop to zero. There's probably some method to this madness, but nobody on the list has figured it out yet. Part of the problem seems to be that the setting changes over time -- I can go back to a patch that I could swear works one way, and it's working the other way! I've given up on depending on the ribbon controller for long-term modulation tasks.
If you find out what's going on, please post the information here. I'm sure lots of owners would like to know what the secret is.
-BW
Bruce Wahler
Ashby Solutions™ http://music.ashbysolutions.com
978.386.7389 voice/fax
bruce@...
2003-10-09 by RayMaxer (Digital Illusions)
Hi Bruce and Jimmy and Joe... and all others
Well... as I figured out (and as far as I remember there is some notice in the manual about it) it works depending on assignation of RbX to Pitch Up in Ctrl Matrix this way :
Just assigning RbX to Cutoff with no other assign of RbX in the whole Matrix to anything else makes ribbon stay at the position where you pulled finger from it.
Assigning RbX to "Pitch Up" (with 0 amount) in another slot makes it return to default position, which (AFAIR and AFAIN) may be different (meaning center or the left edge of ribbon) on the destination to which RibbonX is routed..
This all works as it should for me practically always, but I think I had a situation not long time ago, when I couldn't figure out why it was working still one way when I thought that conditions were for another..
This may be linked to : I am not sure how it works when there are several destinations (besides Pitch Up) selected .. does anything change or not.
Currently, I just checked the simple Cutoff and Pitch Up thingy on a Init patch to be sure about what I am writing..
Hope that helps a bit, but let me know if it doesn't work this way or anything else you'll find about it.
Ray.
To: AN1x-list@yahoogroups.com
Sent: Thursday, October 09, 2003 5:09 PM
Subject: Re: [AN1x] Ribbon stuck at lowest level
Hi Joe,
>leave off.
>replaced?
-BW
Thanks all for your help. It seems to me though that on every patch
that uses the ribbon it drops to the left edge once I touch anywhere
on the ribbon. Perhaps you can test this for me. On the stock
patch "Chick" 066, when I first bring it up and play it's sort of a
bright analog brass lead sound. Once I touch the ribbon (anywhere on
the ribbon) there is alomst no sound at all. Only a very muted pluck
sound. My assumption here is that the ribbon controller is stuck in
the left edge position because of a physical problem with the ribbon.
Can someone try that patch and let me know what you get? If you get
the normal sound rather than the muted one that should prove that
there is something amiss with mine.
Thanks again for all your help,
Joe
PS I reset all programs to the original values as instructed in the
manual.
--- In AN1x-list@yahoogroups.com, "RayMaxer \(Digital Illusions\)"
another..
change or not.
> Ray.
> From: Bruce Wahler
> Hi Joe,
it
is
still
relase to
where i
> >leave off.
bad?
and
> >replaced?
> Regards,
> -BW
Could you send me the patch , I don't have any originals left in my AN-1x , i think :-)
[in case you are new to sysex dumping]
select the patch , press "Bulk Dump" , select one voice and record into seq. or some Sysex program and export as a MID file (or Logic file if you use Logic).
and send me to personal e-mail..
p.s. though "Global" setting may make some influence here too ...
p.p.s. in fact , if that happens after global reset of An-1x, then I think you right that it's a broken ribbon :(
Ray.
Sent: Thursday, October 09, 2003 10:30 PM
Joe
manual.
2003-10-10 by Ed Edwards
Joe,
Unfortunately, I think you're analysis is right. Probably a hardware
problem. That stock patch does not behave like that on my AN. The symptom
of immediately going to a value when moved is the way a digital sensing
circuit behaves with a bad control. Basically, the software doesn't waste
valuable time continuously polling the controllers - it relies on interrupt
hardware signals to change a value. So what's going on is your ribbon is
somehow stuck on it's lowest value, but the operating system doesn't know
about this until you generate an interrupt by changing the controller - and
in your case when it's detected by the software it always changes to the
lowest value.
If you're brave and not intimidated by a screwdriver, pull out the 30 or so
screws on the back of the AN1x and check any connectors to the ribbon cable.
They may be just dirty or loose and re-seating them might be all that's
wrong.
Ed Edwards
Leader: Ezekiel's Wheel »»»»Retro-Progressive Rock««««
http://www.untiedmusic.com/ezekiel
http://artists.mp3s.com/artists/227/ezekiels_wheel.html
Hi Ray,
Thanks for this discovery. I'll test it on my AN1x. One point which should
be added is that this quirk has been discussed previously and IIRC somebody
noticed that if the synth was set for Mode 1 that the behavior was more
predictable. The Mode thing is for how the synth generates and responds to
MIDI... I forget where you access this... might be something drastic you
have to do to change it like holding down some keys on boot-up. Anyhow, I
use mine in Mode 2 (the less reliable one for the ribbon) due to having to
send some non-standard MIDI messages to it via a guitar synth. (I suppose
that I could have mined the list archives to find out specifics on this, but
I'm lazy and have just decided to live with it. Laziness has helped my
memory though by forcing me to remember which patchs the ribbon behaves
with.)
Ed Edwards
2003-10-10 by RayMaxer (Digital Illusions)
you're welcome.
Yeah, I know about those modes..
in fact, I wrote a "Random Patch Generator" small proggie for AN-1x before Gary implemented this feature into AN1x-Edit. And this proggie used CC's to alter all the params in he patch, and because of that AN-1x had to be set to MODE 2 (in which practically all parameters have specific CC hard-preset to control it).
And yes, the MODE is changed on bootup by holding "ASSIGN" button.. just checked , it's on Page 96 of manual.
and BTW, as I already opened manual, see page 75 at the top .. small text.. reagrding Ribbon and releasing it...
dont know about influence of "Mode" on ribbon behavior though...
Ray.
Sent: Friday, October 10, 2003 6:53 AM
Hi Ray,
with.)
Ed Edwards
