Can I use An1x voices with the An200
Re: Can I use An1x voices with the An200
2003-09-02 by Jon
--- In AN1x-list@yahoogroups.com, "JOSEPHMASCIS" <josephmascis@y...> wrote:
> Can I use An1x voices with the An200 and if Yes how ? (Midi dump ,
> etc..).
> Marq from France
AN1xEdit (Mac/Win) will allow you to load AN1x Voices into an AN200. Bear in mind
that only Scene1 will translate to the AN200 - and make certain you put in AN1xEdit
into PLG150 Mode (this is an option from the menu bar in AN1xEdit.) You'll find a
copy of AN1xEdit for download in the Files section here at Yahoo! Groups http://
groups.yahoo.com/group/AN1x-list/files
good luck.
Jon
2003-09-10 by leperajd
Hi,I tried loading voices to the an200 with the an1x editor as
described below checking plg150an mode to load to an200 and it doesn't
work for me.I am downloading to desktop or floppy,then unzipping,no
go,an1x editor window pops up, says wrong file version.I tried this
with many patches to no avail.Am I downloading to wrong place or ?.I'm
a newbee to downloading patches.Maybe I need a primer on the steps to
downloading patches correctly.Thanks,Help appreciated JD LePera-- In
> > etc..).
> > Marq from France
Bear in mind
put in AN1xEdit
You'll find a
Groups http://
> good luck.
> Jon
Hi,Using win 98.I tried loading voices to the an200 with the an1x
editor as
> > etc..).
> > Marq from France
Bear in mind
put in AN1xEdit
You'll find a
Groups http://
> good luck.
> Jon
2003-09-11 by leperajd
I should add that a few times when loading to the an200 I got the
flashing error message 3 and 4.Buffer full etc.JD In
> editor as
doesn't
?.I'm
to
<josephmascis@y...>
dump ,
> > > etc..).
> > > Marq from France
AN200.
> Bear in mind
you
> put in AN1xEdit
AN1xEdit.)
> You'll find a
> Groups http://
> > good luck.
> > Jon
2003-09-11 by Jon
Here are some suggestions:
1st, download and unzip the AN1x voices to a directory (folder.) Most the Voices from
the Files section *should* contain the *.an1 suffix identifying the file type but not all
do. If the file does not contain the *.an1 suffix, use the Open command in AN1xEdit
to open the file and then use the Save command. This will create the correct file type
bit which is sometime 'lost' going from Mac <> PC and/or Zip<>Sit.
2nd, once you have the file type sorted out and have a working Voice bank in
AN1xEdit you can switch AN1xEdit into PLG150 Mode but it will _probably_ close the
currently open file and open an empty file - simply reopen the file you intended to
work with while in PLG150 Mode
If you receivet Buffer Full or Overrun messages the likely cause is your MIDI Interface.
Cheap sound card MIDI Interfaces, i.e., SoundBlaster type cards, are NOT very robust
and easily overrun by a data intensive files such as *.an1 files. Some USB MIDI
Interfaces suffer the same. I suggest you attempt to transfer only a a few voices at a
time or no more than the 1st 64 Voices in a bank to avoid the overload error. For the
record, AN1x SysEx dumps are considerably larger on average than most synths. This
is unavoidable and the the result of Yamaha's data structure design. This has been
discussed at length on this list - if you're interested in learning more search the list
archive for posts from Gary Gregson and you'll find this topic discussed often.
Also, keep in mind the AN1x Voice structure allows for two Scenes per Voice where as
your AN200 does not - and the Effects structure is not as comprehensive. This will
likely result in some unavoidable discrepencies in sounds played back on the AN200.
It's not a big deal - just something to be aware of.
Post back if you need additional help.
Jon
> > editor as
> doesn't
> ?.I'm
> to
