re: output volume.
2003-08-13 by spaceanimals
Index last updated: 2026-03-31 13:41 UTC
2003-08-14 by shaktisshadow
> Are all the patches quiet or just some?All patches are low in volume.
> If it's a used synth, check the patches. What's the VCA setting? TheI checked all the parameters corresponding to volume and
> filter settings? There's a lot of ways to mess up the volume. The
> output volume of my An1x is louder than my other synths.
2003-08-14 by Bruce Wahler
>Thanks for the reply Jimmy!It could be a combination of the AN1x and the headphones you are using. I use a pair of Sennheiser HD580's, and while the volume is adequate, it's not overly loud. I was prepared for this: All of the reviews said that the Sennheisers really need a strong amp to drive them, because of their high impedance.
>What are you using for an amp?
>I have been using headphones ( a couple different types)
2003-08-14 by Mike Metlay
> Hi Shakti,Sorry but no, you have it backwards, Bruce. Years ago, most speakers were 8
> impedance.
> Years ago, most headphones were 8 ohms, and all headphone outputs on stereos,
> etc. were set up to handle this load. These days, headphone impedances are
> all over the place, from around 30 ohm to tens of thousands of ohms.
> Regards,
> -BW
> < > < > < > < > < > < > < > < > < > < > < > < > < > < > < > < > < > <metlay / atomic city / metlay@... / http://www.atomiccity.com
>using. I use
> Bruce Wahler said:
> > Hi Shakti,
> > a pair of Sennheiser HD580's, and while the volume is adequate,it's not
> > overly loud. I was prepared for this: All of the reviews saidthat the
> > Sennheisers really need a strong amp to drive them, because oftheir high
> > impedance.on stereos,
> > etc. were set up to handle this load. These days, headphoneimpedances are
> > all over the place, from around 30 ohm to tens of thousands ofohms.
> >speakers were 8
> > Regards,
> > -BW
> ohms, and headphones were designed to be driven by the same ampcircuit that
> fed the speakers without anything getting overloaded (the speakers,the
> headphones, or most importantly the amp itself, usually tube-drivenin those
> days). To do this they had to have a very high impedance, 600 to2000 ohms, so
> they could be strapped across the amplifier with the speakerswithout
> affecting the amp load much.(and
> When portable cassette players came out and required lower-impedance
> headphones to get decent level from their tiny battery-powered amps
> didn't hook up to speakers anyway), that's when impedances startedto drop.
>others are
> Many good headphones today still use a 600 ohm impedance, but
> specifically being designed with lower impedances. As an example,AKG still
> makes the excellent K240 M headphone, a 600 ohm phone that's oftenused for
> orchestral sessions where many headphones can be chained inparallel without
> the net impedance dropping too low (you can chain 75 sets and stillhave an
> 8-ohm load). But AKG also recently released the K240 Studio, aredesigned
> headphone with a 55 ohm impedance.us!!"
> mike
> "Run for your lives! Lofty's figured out he's BIGGER than all of
> metlay / atomic city / metlay@a... / http://www.atomiccity.com
2003-08-14 by Peter Korsten
> Many good headphones today still use a 600 ohm impedance, but others areI have the K240Ms. Excellent headphones, but you really need to turn the
> specifically being designed with lower impedances. As an example, AKG still
> makes the excellent K240 M headphone, a 600 ohm phone that's often used for
> orchestral sessions where many headphones can be chained in parallel without
> the net impedance dropping too low (you can chain 75 sets and still have an
> 8-ohm load). But AKG also recently released the K240 Studio, a redesigned
>Sorry but no, you have it backwards, Bruce. Years ago, most speakers were 8No, the Koss headphones that I used in '71-73 were definitely 8 ohms. I worked for Radio Shack all through college, and nearly every headphone we ever sold in those days said "8 ohms" on the box. Back then, most stereo manufacturers powered the headphone jack by putting a 100-500 ohm resistor in series with each side of the main outs, to both prevent the cans from loading down the main speakers, and to prevent the headphones from taking the full brunt of the amplifier. My trusty Sennheiser HD414's, OTOH, were about 2,000 ohms, and so were relatively easy to fry by turning the levels up; that 150 ohm resistor didn't help at all. :^(
>ohms, and headphones were designed to be driven by the same amp circuit that
>fed the speakers without anything getting overloaded (the speakers, the
>headphones, or most importantly the amp itself, usually tube-driven in those
>days). To do this they had to have a very high impedance, 600 to 2000 ohms, so
>they could be strapped across the amplifier with the speakers without
2003-08-15 by Ed Edwards
> Sorry but no, you have it backwards, Bruce.Lab equipment... man I want an analyzer to solve this with! A Google search
To: <AN1x-list@yahoogroups.com>
Sent: Thursday, August 14, 2003 3:24 PM
Subject: [AN1x] Impedance and volume
> Bruce Wahler said:
> > Hi Shakti,
I use
high
> > impedance.
stereos,
are
> > Regards,
> > -BW
that
those
ohms, so
> headphones to get decent level from their tiny battery-powered amps (and
> didn't hook up to speakers anyway), that's when impedances started to
drop.
still
for
without
an
> mike
> "Run for your lives! Lofty's figured out he's BIGGER than all of us!!"
> Community email addresses:
> Post message: AN1x-list@yahoogroups.com
> Subscribe: AN1x-list-subscribe@yahoogroups.com
> Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com
> List owner: AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
> http://groups.yahoo.com/group/AN1x-list
2003-08-16 by shaktisshadow
>turn the
> volume up. On the AN1x, this used be somewhat of an issue, butthey're
> connected to the mixer now, where they have their own volumecontrol.
> - Peter
