An1x output volume is low- wheres the internal switch???????
2003-08-12 by shaktisshadow
My AN1x's volume seems really low. I read on sonicstate that there is
an internal volume switch in the AN1X that controls between -6, 0,
and +6 db:
fromm sonicstate.com:
oatbran71@..., theres an internal switch that allows you to
set the VCA output from -6 0 +6 and +12 db output, I think that 0db
is good enough, but if its too low try setting it to +6 db.
You can also do this with the an1x editor on the VCA section
My questions: How do I open up the AN1x and where is the switch.
Thanks for your help!!
