Re: [AN1x] Stepping on the pedal
2003-07-22 by Ed Edwards
Jerry,
It might be that the EV5 has the wrong resistance. The Yamahahaha FS7s I
have don't seem to step when set on volume. Now on some other settings
there's a lot of stepping, but that's due to the hyplodipuladed squantum
mechanic synth engine and its personal interpretation of Planck's Constant.
Ed Edwards
Leader: Ezekiel's Wheel »»»»Retro-Progressive Rock««««
http://www.untiedmusic.com/ezekiel
http://artists.mp3s.com/artists/227/ezekiels_wheel.html
2003-07-22 by Bruce Wahler
Hi Jerry,
The Yamaha volume pedal standard is completely opposite of most of the rest of the world:
Ernie Ball/Roland/Old Korg Standard --
Tip = potentiometer (pot) wiper
Ring = voltage reference
Sleeve = ground
Yamaha/New Korg Standard --
Tip = voltage reference
Ring = pot wiper
Sleeve = ground
In case you're not familiar with the names, a standard 1/4" guitar cable has only the "tip" and "sleeve" connections; a stereo cable adds the "ring" connection between the tip and sleeve.
This could be part of your problem. If you need to use a Roland pedal with a Yamaha synth, or vice versa, you have to swap the "tip" and "ring" connections on the stereo 1/4" plug, or the pedal response may be quite erratic. This can be done by cutting the plug off and soldering on a new one, or by making a short adapter cable (1/4" stereo jack to 1/4" stereo plug) that crosses the wiring inside the adapter.
-BW
Bruce Wahler
Ashby Solutions™ http://music.ashbysolutions.com
978.386.7389 voice/fax
bruce@...
2003-07-22 by Jerry Aiyathurai
Wow. Cool Info. Thanks Ed and Bruce. I feel much better about my blue
beauty. I think I'll just pony up for the Yammie pedal.
Jerry
> Sleeve = ground
> Ring = pot wiper
> Sleeve = ground
adapter.
> Regards,
> -BW
> Bruce Wahler
> bruce@a...
Hi Jerry,
FWIW, the Yamaha FC-7 is one of the best volume pedals ever made. Korg uses it (with Korg logo, of course) on their BX-3 and CX-3 organs, and I've converted several for Roland users because they like them better than the Roland equivalents. I have one FC-7 that I bought in 1986 that is still going strong.
-BW
Bruce Wahler
bruce@...
>Jerry
