--- In AN1x-list@yahoogroups.com, "Jon <jondl_2000@y...>"
<jondl_2000@y...> wrote:
> --- In AN1x-list@yahoogroups.com, "caravan102000
> <hakan.t@c...>" <hakan.t@c...> wrote:
> > if i try to load a patch from the editor , it hangs, and i,ll
have to
> > shut the program off, but when i try to send the program from
> cubase
> > there´s no problem. I want to use the etitor
> Okay, I'm a bit confused. Let's try and clarify:
> You say a program (an AN1x Voice) will load from Cubase to the
> AN1x. That implies you are loading AN1x Voices as either .mid or
> .smf files from Cubase to the AN1x. Is this correct?
> Whe you say 'editor' do you mean AN1xEdit? If so, does AN1xEdit
> hang when you attempt to load the program (Voice) into the AN1x
> - or - when you try to open the program bank in AN1xEdit?
> Please post back with some details regarding your computer
> platform, software versions and type of MIDI Interface. This info
> will help trouble shoot your issue.
> regards,
> Jon
thank you jon.
i´m using win 98 with the audigy sound card.
i´m having no problem recieving midi(patches) from cubase. but when
i try and recive let´s say 64 patces from an1x editor it hangs , i
only get the first patch. and i have to shut down the program and
start it again. I hope you got an answer.
