SW+AUDIOPHILE
2002-11-28 by DMANX@talk21.com
I have tried contacting tech support, but I think they had difficulty solving the problem. All I want to do is record my sw1000 synth sounds with vsti audio sounds from the audiophile, then export it all as a wave file to hard disk and CD. However the problem lies with the different bit/sample rates from both cards.
For example if someone is recording from various outboard gear with various bit/sample rates which im sure they do, using the audiophile with cubase, how do they overcome this. Not all outboard gear outputs the same.
Also using the setup below,I find that the signal to noise ratio is low using vsti from the audiophile when compared to playing midi synth sounds from the sw1000/an150, why is this?
This is my setup:
SOUND CARD SETUP
EQUIPMENT=PIII 800MHZ, 384MB RAM, WIN XP PRO,CUBASE 5.1,SB LIVE,MATROX G400, SW1000XG\AN150 SYNTH CARD,M AUDIOPHILE 2496
NOTE-SW1000XG DIGITAL OUTPUT SP/DIFF(AD 20 BIT/44.1KHZ) CONNECTED TO AUDIOPHILE DIGITAL INPUT SP/DIFF(24 BIT/96KHZ).RECORDING IN CUBASE5.1
MIDI SETUP + MIDI-OX/MIDI-YOKE (SO TALKS TO 3 APPS-CUBASE,XGEDIT AND AN1XEDIT
MIDI/ANALOG SYNTH CARD/MIDI INTERFACE = SW1000XG+AN150 (AD=20BIT/DA=18BIT,ALL AT 44.1KHZ)
XGEDIT
MIDI INPUT=NONE
MIDI OUTPUT A=MIDI-YOKE 1
MIDI OUPUT B=SW1000 SYNTH 2
AN1XEDIT
MIDI INPUT=NONE
MIDI OUTPUT=MIDI-YOKE 1
MIDI-OX
INPUT=MIDI-YOKE 1
OUPUT=SW1000 SYNTH 1
CUBASE MME SETUP
MIDI INPUT=SW1000 MIDI IN
MIDI-YOKE 1
MIDI OUTPUT=SW1000 SYNTH1
SW1000 SYNTH 2
SW1000 MIDI OUT
CUBASE OPTIONS-MIDI FILTER
SYSEX THRU=TICKED
SYSEX REC=UN TICKED
CUBASE OPTIONS
PLAY IN BACKGROUND=TICKED
AUDIO\VSTI CARD SETUP
AUDIO REC/VSTI CARD = M-AUDIOPHILE 2496 (SET AT 24BIT/96KHZ PLAY+REC)
CUBASE ASIO DIRECT X SETUP
DIRECT SOUND OUTPUT=SW1000 WAVE OUT
M AUDIO AP 1 /2
DIERCT SOUND INPUT=SW1000 WAVE 2
M AUDIO AP 1 / 2
M AUDIO AP SP/DIFF
FULL DUPLEX=TICKED
DIRECT SOUND OUTPUT=TICKED
CUBASE ASIO MUTIMEDIA SETUP
OUTPUT PORTS=SW1000 SYNTH 1 WAVE OUT
SW10000 SYNTH 2 WAVE OUT
M AUDIO AP 1 / 2
INPUT PORTS=SW1000 SYNTH WAVE IN
M AUDIO AP 1 / 2
GLOBAL SETTINGS
SYNC REC=SAMPLE POSITION OUTPUT
CARD OPTIONS=FULL DUPLEX
OPEN ALL DEVICES BEFORE START
16 BIT ONLY
CUBASE AUDIO SYSTEM SETUP
ASIO I/O=M AUDIO DELTA ASIO
SAMPLE RATE=96 KHZ
AUDIO CLOCK SOURCE=SEE CONTROL PANEL
MONITORING=GLOBAL DISABLE
MIDI SYNC REF:=AUDIO CLOCK
FILE CACHE SCHEME=TAPE REC/AUDIO SEQ
PRIORITY SETTING=NORMAL1
SCHEME 3
MIDI/AUDIO DELAY=0
M AUDIO CONTROL PANEL
MONITOR SETTING=ALL FADERS UP AT 0db
SP/DIFF=PROFESSIONAL
PATCH BAY ROUTER
H/W OUT 1 / 2=WAVE OUT 1 / 2
H/W OUT SP/DIFF=WAVE OUT SP/DIFF
HARDWARE SETTING
MASTER CLOCK=SP/DIFF IN
SP/DIFF SAMPLE RATE=96KHZ
DMA BUFFER SAMPLE=384
Regards
DMANX
talk21 your FREE portable and private address on the net at http://www.talk21.com
