tried it but still won't work
2002-11-04 by DJGaryB
I tried the suggestion you gave me but I'm still having a problem.
To make it simple this is what I did.
The AN1X is set to patch 002 the MIDI TX Ch is set to 1 the RX Ch is
also set to 1 and the Device number is also set to 1.
On the MPC2000 I have the MIDI set to 1A Sequence 1 Track 1
I entered F1 and inserted program change then set the number to 1
Recorded something and it played.
Step 2
Went to sequence 2 on the MPC2000 and laid down the drum track on
track 2, kept track 1 for the midi, set that to 2A, entered F1 and
inserted program change then set the number to 2.
Went to the AN1X and set the MIDI TX Ch to 2 and the RX Ch to 2 and
set the Device number to 2 and used patch 003.
Now this is where it gets tricky when I switch from sequence 2 to 1
the sound that plays is patch 003 instead of 002.
If there is any way that I can get this right please help me.
Went experimenting on my own here now.
MPC Seq 1 trk 1 midi 1a (prg 119 not the insert but from the main
screen)
AN1X MIDI TX Ch 1 RX Ch 1 Device 1
MPC Seq 2 trk 1 midi 2a prg 118 (same as above)
AN1X MIDI TX Ch 2 RX Ch 2 Device 2
When I did this the sounds changed but there was a delay in the
switch, what should I do here now to correct this?
Re: tried it but still won't work
2002-11-05 by Jon
Hello DJGB,
problem.
Ch is
number to 1
> Step 2
track on
2 and
to 1
main
> screen)
Couple of thoughts...
1) You should not need to reset the MIDI TX Ch and RX Ch each
time. You only need to change the TX Ch when using the AN1x
as a controller in a hardware setup where you need to record the
output of the AN1x into a sequencer that does not offer
rechanneling. I've no hands on time with a MPC2K but I'm fairly
certain it will rechannel as would a software sequencer
(CUBASE or LOGIC or SONAR, etc.)
The AN1x is bitimbral, meaning it is capable of playing back
each of the two Scenes in a Voice on a seperate MIDI Channels -
that's why the RX parm is can be set independently per Scene.
(Unfortunately, the TX parm is a common parameter which
would have improved the AN1x usefulness as a controller. Oh
well.) You don't need to reset the RX Ch for each Voice - leave it
set to a specific channel. You only need to se the RX Ch for the
2nd scene when you want to use the AN1x as a bitimbral sound
source.
2) You should leave the Device No, parm set to All or a specific
Device number, such as '1', and never change it. This parameter
is useful ONLY when there is more than one AN1x device in your
MIDI Setup. The Device No parameter would allow your host or
hardware sequencer to distinguish one AN1x from another. For
example, say you had a Kenton Plugstation with multiple
PLG150AN cards installed - you would need to set each card to
its own device number so that each card could be identified
correctly.
3) There will always be a pause in audio output of the AN1x, and
many other synths for that matter, when a program change
command is received. There is a great deal of number crunching
going on with the Analog modeling sound engine - the AN1x
does not have the computational horse power not to interrupt the
sounds during a program change (not many synths do.)
regards,
Jon
2002-11-14 by WoofwoofX
Hi gary,
You don't need to change the RXCh on the AN1X each time you change
something on the MPC...
For ex. Put your AN1X RXCh to 1 (or 2) and leave it...
On AN1X TXch is only used if you want to control your MPC fom AN1X so
you can leave it at 1 in your case there's no need to even connect a
cable.
On the MPC you can use one MIDI output and assigne CH1 (or2) to TX
depending on the RXCh in AN1x and leave it on the sequences that
you're going to use.
So Now you have TXCh1A (MPC) on the part used to control the AN1X
RXCh1 (AN1X) in all your sequences.
But be aware that the sound will cut when you change so don't
expected to be lik continuous... because the Synth needs to change a
whole lot of parameters and effects when it changes the patch...
and bare in mind that Prog Change =000 could be equivalent to AN1X
001.
Excuse My French
Danny
is
> Step 2
> screen)
