re: AN1X volume
2002-10-18 by spaceanimals
Jim Acker brings up some good points. There's a reason the old Mini Moog leads get used so often. When you've got a couple of guitars, a bass, and a drum set it's hard to cut through the mix. My guess is the percussive sounds will cut through, and the sustaining pad like sounds will be lost completely. Rainbow Jimmy http://www.spaceanimals.com http://www.mp3.com/spaceanimals
