2 Separate audio/midi cards
2002-08-03 by DMANX@talk21.com
I need to use my sw1000xg and plugin board for its on-board midi sounds.And I need to use a low latency 24bit/96khz audio card for soft synths and recording.My question is how would I configure this in cubase so I can record the sw1000xg sounds through this second audio card ?How should it be wired up? do i need any extra gear?How do I connect my midi keyboard to access these 2 cards.
Also the sw1000xg outputs it sounds at 24bit/44.1khz,so how do mix it with sounds recorded from a 24bit/96khz audio card.
Any advise please?
Regards Dmanx.
talk21 your FREE portable and private address on the net at http://www.talk21.com
Re: 2 Separate audio/midi cards
2002-08-04 by jondl_2000
--- In AN1x-list@y..., DMANX@t... wrote:
> Hi,
If you don't get an answer here, check this Cubase specific
forum:
http://linux1723.dn.net/cgi-bin/ubb/forumdisplay.cgi?action=topic
s&forum=sound+cards&number=5&DaysPrune=10&LastLogin=
I would think you'd want to take the S/PDIF outfrom the SW1K
and route it to the 24/96 card S/PDIF input. You'll probably need
to set the clock rate on the 24/96 to match the SW1K but I
wouldn't see that as a problem. I can't see any benefit to
recording the output of the GM sound set at 96kHz ;-) Check your
manual for specific.
Jon
> Any advise please?
> Regards Dmanx.
Re: [AN1x] 2 Separate audio/midi cards
2002-08-04 by John Temprile
The way that I do it is re-route the output from the one card
back to the input of the other, through a mixer. I have two
cards in my system that I do this with.
Treat the second card as an external synth ...
Jt
 --- DMANX@... wrote: >
> Hi,
> Any advise please?
> Regards Dmanx.
> Community email addresses:
>   Post message: AN1x-list@yahoogroups.com
>   Subscribe:    AN1x-list-subscribe@yahoogroups.com
>   Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>   List owner:   AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
>    http://groups.yahoo.com/group/AN1x-list
> Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
Do You Yahoo!?
Everything you'll ever need on one web page
from News and Sport to Email and Music Charts
http://uk.my.yahoo.com
