Yeah - just select something else than "DIR" .. Dir is an Absolute controller...
and all other settings ( +1. + 50....) are Rel. controllers..
So that if you don't touch the controller after selecting it in matrix target
(after making amount to something else than DIR) the sound won't change.
Ray.
Sorry for my clumsy english...
Ed Edwards wrote:
> > spaceanimals wrote:
> > > Ever notice when you set a parameter to be modulated in the matrix
> > > that the damn machine resets the value on the patch.
> Oh, yeah. I HATE this - it wastes too much time having to try to recover the
> sound.
> > Jimmy -
> > that's easy to fix -
> > when you select a target , at that very moment you usually have a "DIR"
> > selection in the amount of this matrix slot.
> > So the source's current value is directly applied to dest.
> > You better select the amount at first , like set it to "+1" and then select
> > the target - then you won't have this problem, as you just need to get ribbon
> > (f.ex.) to neutral position to get any modulations done to the target away or
> > turn modul. wheel to full 0 for the same and so on.
> This seems reasonable, but sort of backwards in logic. So you're saying that
> first I need to set an amount BEFORE I select a parameter in the matrix? Nasty
> logic, but I'll give it a try.
> Ed Edwards
> Leader: Ezekiel's Wheel \ufffd\ufffd\ufffd\ufffdRetro-Progressive Rock\ufffd\ufffd\ufffd\ufffd
> http://www.untiedmusic.com/ezekiel
> http://artists.mp3s.com/artists/227/ezekiels_wheel.html
> \ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd
> From: "RayMaxer" <digil@...>
> To: <AN1x-list@yahoogroups.com>
> Sent: Sunday, June 16, 2002 5:45 PM
> Subject: Re: [AN1x] matrix screwups
> > Hope that helps.
> > (I am speaking about the way of working with AN-1x via AN1X-Edit here)
> > Ray.
> Like set the
> > > filter cutoff to the Z ribbon controller and the next thing you know,
> > > the patch isn't making any noise because the filter cutoff got turned
> > > down to 0. This means anytime I call up any parameter in the matrix,
> > > I first have to check to see what the parameters are first, in case
> > > they get changed inadvertantly.
> > > Rainbow Jimmy
> > > http://www.mp3.com/spaceanimals
> > > http://www.spaceanimals.com
> > > Community email addresses:
> > > Post message: AN1x-list@yahoogroups.com
> > > Subscribe: AN1x-list-subscribe@yahoogroups.com
> > > Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com
> > > List owner: AN1x-list-owner@yahoogroups.com
> > > Shortcut URL to this page:
> > > http://groups.yahoo.com/group/AN1x-list
> > > Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
> > http://www.mp3.com/raymaxer
