No F ? No B ?
No F ? No B ?
2002-05-29 by Jaun Manuek
a friend of mine was delighted to
get an An1x in exchange for a XP10.
Now a really weird problem appeared on his new machine:
  any F and B key doesn't trigger any sound !!!
have you ever had this ???
do you know what could be ?
we already did some factory set but it still doesn't work !
if you can help, he will feel quite back...
thanks !
jma
_________________________________________________________
Do You Yahoo!?
Informaci\ufffdn de Estados Unidos y Am\ufffdrica Latina, en Yahoo! Noticias.
Vis\ufffdtanos en http://noticias.espanol.yahoo.com
Re: [AN1x] No F ? No B ?
2002-05-29 by Bruce Wahler
This sounds like a problem with the electronics that scan the keyboard.  Modern keys don't directly connect to their sound source; instead, they are connected into row/column digital scanners, like those of a computer keyboard, and then the scanner decides which notes are played.  If we look at the keyboard in that way:
C  = 1 (any C)
C# = 2 (any C#)
D  = 3 (etc.)
D# = 4
E  = 5
F  = 6 *****
F# = 1
G  = 2
G# = 3
A  = 4
A# = 5
B  = 6 *****
It looks like the electronics for column #6 is out of whack.  It's possible that it could be a loose connection on a cable or an IC socket, but more than likely, it needs to have some part(s) replaced.
-BW
Bruce Wahler
Design Consultant
Ashby Solutions\ufffd   http://consult.ashbysolutions.com
CloneWheel Support Group and HiNote moderator
978.386.7389  voice/fax
bruce@...
