Index last updated: 2026-04-03 20:49 UTC
remote controlling VST
2002-05-09 by Peter Scullion
Does anybody uses the knobs on thre AN1X to control audio parameters within VST or other sequencer, & if so  how do you set this up?
Is ytheir templates available?
Thanks in advance
Re: remote controlling VST
2002-05-10 by jondl_2000
set this up?
> Thanks in advance
Hello Peter,
Yes, there are templates available. Please check the FIles
section at Yahoo! Groups and you'll find directories for Cakewalk,
Cubase, Logic, and more:
http://groups.yahoo.com/group/AN1x-list/files
Please post back to the list with any specific questions you might
have on these resources. Somebody will try to help.
regards,
Jon
2002-05-12 by Peter Scullion
Hi John,
thanks, as per usual for your speedy reply, unfortunatley I think you
misundertood my question, so I'll post it again more clearly.
What I'm trying to do is use the knobs on the AN1x to control VST audio
parameters, such as pan ,FX sends, faders etc. so I've got 'harware
faders/pots' rather than using the mouse.  like  steinbergs Houston, or
Logic's control are designed to do (obviously without that level of
control).
Thanks in advance
P
________________________________________________________________________
Message: 1
   Date: Fri, 10 May 2002 04:23:59 -0000
Subject: Re: remote controlling VST
set this up?
> Thanks in advance
Hello Peter,
regards,
Jon
2002-05-12 by jondl_2000
> Hi John,
you
VST audio
'harware
Houston, or
of
> control).
That's what I assumed you meant which is why I pointed you to
the FIles section :-)
There are Mixer Maps for Cubase in the FIles section under the
Cubase directory which will allow you to control AN1x functions
from within Cubase and vice versa. Obviously you may need to
make corresponding updates to the CC's transmitted by the
Assign Knobs on the AN1x under the Ctrl Device and Ctrl No.
items.
Reg is our resident Cubase guru (not that I mean to discount
anyboduy else's experience) and would probably offer advice (if
asked nicely) on tailoring these templates to your specific needs.
I could give a go at helping with Logic Audio (and maybe some
Opcode stuff too) but I'm not up on my Cubase :-( Sorry.
Jon
