LAMP4.8.1 & AN1x Problem....Help........
2002-04-29 by betek070167
AN1x doesn't respond to any MIDI data from LAMP4.8.1. I'm using Mac OS9.2.2, MIDIMAN midisport 2x2....I created Multi Instrument object on Environment window and click 1 & 2 of it....then select these from Track column area on Arrenge window. I tried every trouble shoot idea I can think of .....Yes, MIDI cable is good....OMS setting is good.....anyway, weird thing is this one MIDI cable (which is connected midi in on AN1x) to another synth's MIDI in, this synth does respond.....so this makes me think all settings ( LAMP, OMS, Midisport....) should be good.....AN1x is the only thing I can think of causing this trouble.....but then, again.. I connect my Master Keyboard controller 's MIDI out to AN1x's MIDI in directry ( Bypassing LAMP, OMS, midisport).....AN1x does respond...so this makes me think AN1x's MIDI in jack is working fine also......( I got this AN1x used.....so I thought there's something wrong with this particular AN1x....) I mean AN1x's MIDI parameter is just Send ch and Receive ch setting and Local ON/OFF that's about it, right.....so I don't think I'm missing anything.... Now I gave up......Someone please give me any hint, advice anything before I pull all my hair out..... Thank you guys in advance.......help.........me.............
