Setting Tempo to Midi
2002-01-06 by Andy Fearon
Hello everyone, One thing that has bothered me about my An1x over the last few years is what happens when you set the tempo to midi on a patch that uses arps or seqs, i.e. nothing! I would like to be able to send single notes (or chords) from Cubase to trigger the An1x to play the sequence or arpeggio at the tempo set by Cubase. This is not to be confused with the Pattern Transmit Channel which you can use to transmit the actual notes played by the Arp or Seq via midi which you can then capture in Cubase. I hope you can help. Andy
