Index last updated: 2026-03-31 13:41 UTC
Re: [AN1x-list] 3-4 OCSILATOR'S
2001-01-12 by Bastiaan van de Werk
Unless it has a dual mode you can't do it...only the An1x can.
3-4 OCSILATOR'S
2001-11-12 by DMANX@talk21.com
I know the an150plg is a 2 ocsilator synth,but i also heard that it is possible to make it 3 -4 ocsilator synth?or make it sound like one?
How can I do this
Regards Dmanx.
talk21 your FREE portable and private address on the net at http://www.talk21.com
Re: 3-4 OCSILATOR'S
2001-11-12 by Jerry Aiyathurai
> How can I do this
Since you have two scenes you can activitate them simultaneously
using the "Dual Mode." This will have all four oscillators active,
with 2 of them will be running through one filter and two through the
other.
In a sense you can make it act like a 6 oscillator synth, since
oscillator 1 splits into two (master and slave) oscillators when in
sync mode. I can't hear both master and slave oscillator in this mode
(only the slave, which is being synced) , but it saves you an
oscillator when creating a sync sound.
Hope this helps,
Jerry
Re: 3-4 OCSILATOR'S
2001-11-13 by Jon
--- In AN1x-list@y..., "Bastiaan van de Werk" <bazziman@h...> wrote:
> are you sure the pluginboard has a dual mode???
Bastiaan, I think you are correct. The PL150AN has ONE scene only - and
that's why the frequent questions regarding the use of AN1x voices on
the PLG150 and AN200.
http://groups.yahoo.com/group/AN1x-list/files/Documentation/
plg150_an_specs.htm
regards,
Jon
Re: 3-4 OCSILATOR'S
2001-11-13 by Jerry Aiyathurai
Fellers:
You are right, I didn't read the question correctly. Sorry.
Jerry
