An1x vs ENSONIQ Fizmo
2001-10-24 by Jason
Ok, I am pretty happy with my An1x, but the Fizmo is really nice and
is easier to make organic sounds, which is where my music has been
heading...
So I'm wondering, could someone point out some pro's-con's for me, as
I bought my an1x for 500 but could get a fizmo for 425 which
supposedly has more features, like a vocoder. thanks. j.
Re: [AN1x-list] An1x vs ENSONIQ Fizmo
2001-10-24 by teomi@cs.com
Hi there.
Fizmo was Ensoniq's last synth before Emu completely took over. I doubt that
we will ever see another Ensoniq synth, and even if we do see one it won't
have that special Ensoniq sound.
I am an Ensoniq freak and I own a bunch of Ensoniq older gear (SD1, ASR10..)
The idea behind the Fizmo is to build a synth around one concept which is
"Transwaves" Transwaves is a synthsis concept that was invented by Bob Yannes
who founded ensoniq and it is kinda like wavw tables but very different..I
won't fill you with details here, but this is a very unique and innovative
way to achieve those "organic" sounds you were talking about. No other synth
can do this!
However, the fizmo was kind of a last call in the sense that it doesn't
really offer anything new. just the idea of Transwaves with a few more bells
and whistles which in my opinion don't make it so versatile.
If I were you i will sray with the an1x and watch for an ensoniq ASR-10 rack
sampler!!! it has the ability to create and play back transwaves pretty much
the same way the Fizmo does, and besides that you get one great sampler that
can import akai and roland sounds with superb effect section (same algorithns
as the DP-4).
If you want to hear a demo of what you can do with Transwaves and the ASR10
go to :
<A HREF="www.soundengine.com">www.soundengine.com</A>
and click onthe ASR-10 link. listen to the demos of "the art of transwaves"
cd.
Hope this helps,
Eitan Teomi
<A HREF="http://ourworld.cs.com/teomi">http://ourworld.cs.com/teomi</A>
Re: An1x vs ENSONIQ Fizmo (long reply)
2001-10-24 by jondl_2000@yahoo.com
and
> heading...
Jason,
A friend of mine moderates the FUG (FIZMO User Group) and hosts the
FUG web page at http://www.cortidesign.com/fizmo/fizmo.html You should
make time to visit this excellent resource. There are plenty of MP3s
demos of the FIZMO posted for you to check out. There is list of known
issues and solutions posted and there's also an excellent interview
with Scott Peer (formerly of Ensoniq, Peavey, and many others) who
designed the FIZMO. You can read more with Scott (and many other synth
developers) at http://www.sonikmatter.com/
as
You're comparing Apples to Oranges. The FIZMO has a compelling and
complicated sound but, it's NOT a V/A like the AN1x and the FIZ is
not intended to emulate analog type sounds. That said, a former Ensoniq
employee and FIZMO developer released a commercial bank of Analog
type sounds so a more contemorary voice selection would be available.
It's available from http://www.soundengine.com/ For that matter, the
FUG is currently trying to put together a big User Bank like the
Waldorf list often does. Anyway, back to the main topic...
A more realistic comparison of the FIZMO would be to a Korg Wavestation
or Waldorf Microwave II which both use digital wavetables as does the
FIZMO with Enosniq's brand name 'Transwaves'.
The *major* problem with the FIZMO is the unusually high number of
units which suffer from a poor power regulator resulting in many
disabled units. Again, check the FUG because this has been extremely
well documented by UGO - who has been through a few fried FIZMOs and
now has an E-mu provided solution (as do others.) The replacement
power supply solution (AC adapter) was a white elephant, i.e., wasn't
the actual fix for the problem. The power regulator is at fault.
The front panel editing is fairly easy to come to terms with but the
voice hierarchey, i.e., Presets and Sounds, is a little more difficult
to envision and manage then the 2x Scenes per Voice AN1x scheme. On
the FIZMO you've two banks of 128 Presets with up to four sounds per
preset. I wish they'd implemented the FIZMO solution for navigating
layers in a Preset on the ASR-X sampler. This would have made a huge
difference in usability for the ASR-X. The built in FX are terrific -
they put the Yamaha effects to shame :-/ I've not used many vocoders
to make a legitimate comparison with anything else. You can access some
hidden parameters on the FIZMO using the free stand alone, OEM Emagic
SoundDiver for FIZMO. There's a bug in the SysEx ID routine on the
FIZ that can be a 'gotcha' when working with the OEM SD but, it's
documented by the FUG so shouldn't be a problem past the initial set-
up. Using the SD editor also provides access to FX parameters not
available form the main unit. Funny how they DID inlcude that feature
on the ASR-X but not the FIZ? You can tell things were rushed with
the last product generation from Ensoniq before the buy out :-(
FWIW - I've recently been "harrasing", i.e., teasing, Scott Peer with
the prospect of making a VSTi FIZMO which would be able to load user
wavetables but I don't think he's realistically considering it.
Doesn't hurt to try though, does it ;-) Just think how many more copies
of his ASR-10 Transwave CD-ROM he could sell too! ha haha
FWIW.2 - as much as I'd like to pick up a FIZMO I purchased a copy
of Absynth (VSTi from NI - Mac only at present) last summer and
indulged myself with a MW II rackmount early this autumn. This covers
the sonic territory as a FIZMO would so I can't really justify a FIZ at
this point. Maybe next year.
FWIW.3 - keep the AN1x and save up for the FIZMO! Best of both worlds
and all that...
HTH,
Jon
2001-10-24 by Jason
Ahhh, I think I will save up, I have liked many of the sounds I'd
made on my An1x so far, but as for the analog comment, I just picked
up a mint SH-2, and that covers my analog bases VERY well :)
2001-10-25 by Bastiaan van de Werk
Fizmo is supposed to be VERY unreliable...i've heard a lot of peeps complain about that.
  To: AN1x-list@yahoogroups.com
  Sent: Wednesday, October 24, 2001 5:30 PM
  Subject: [AN1x-list] An1x vs ENSONIQ Fizmo
  heading...
        Yahoo! Groups Sponsor
              ADVERTISEMENT
  Community email addresses:
    Post message: AN1x-list@yahoogroups.com
    Subscribe:    AN1x-list-subscribe@yahoogroups.com
    Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
    List owner:   AN1x-list-owner@yahoogroups.com
  Shortcut URL to this page:
     http://groups.yahoo.com/group/AN1x-list
