Program change - no thanx?
2001-10-16 by mattias.karlsson@satcom101.com
Hi!
Not to brag but I have a quite big MIDI-system. I try not use to much
MIDI-filtering as I have a quite old MIDIpatchbay. However I've ran
into some troubles when using my An1x. I can't seem to turn of it's
habit of sending program change (and occasionally control change).
So when I switch program on the An1x so do another six synths. Is
there a way to switch it off?
  / Mattias
Re: Program change - no thanx?
2001-10-16 by jondl_2000@yahoo.com
--- In AN1x-list@y..., mattias.karlsson@s... wrote:
> Hi!
There's no method to disable Program Change commands on the AN1x.
you'll need to filter the messages either at your MIDI Patch Bay or on
the remote modules/synths.
However, you can disbale MIDI Change Control's from being trasmitted.
Go to the UTITLITY/SETUP menu and use the [Ctrl Device] to select which
real time controller you wish to disable and use [Ctrl No] to select
'0: off' as the value.
The problem with this solution should be obvious: What to do when you
WANT to send MIDI CC's from the AN1x? A possible solution is to use the
[BulkDump] command and select the 'system' options to dump only those
settings to a generic MIDI SysEx librarian which can then be reloaded
as necessary. This also allows for storing multiple Assign Knob
configurations as seperate SysEx dumps which allows you to work around
the limitation of only one set of Assign Knob settings available at any
one time.
Personally, I don't care for this solution - too labor intensive to
keep organized. I've taken to leaving the AN1x default values in place
and creating customized Environment Layers within Logic Audio to
perform MIDI CC routing and/or filtering. I recommend you pursue a
similar option or resort to filtering at your MIDI Patch Bay.
regards,
Jon
Re: [AN1x-list] Program change - no thanx?
2001-10-16 by Ed Edwards
Do the 6 other synths need to be listening for Program Changes on the same
channel as the AN1x is sending?
Stated differently: Is the AN1x being used as the master controller?
If the answer is no to either question, then you'll just need to get the
synths on different channels.  If the answer is yes to either question, then
you'll probably have to filter the data.
I may be wrong about these being the only solutions, but my band has a bit
of experience with the limitations of MIDI - we use 2 DMC MX-8 MIDI
patchbays, each has 6 inputs and 8 outputs.  We need 2 of them to accomplish
synth routing live... not that there's a huge number of synths (6 sound
engines, 7 controllers, never all used at once... only 4 guys in the band).
The limitations of MIDI become evident when you try to break out of the
"daisy-chain" concept that it was developed for.
Here's a graphic our bassist made that details our setup (in 1999).  It
looks a bit insane because it is.
http://www.untiedmusic.com/ezekiel/hi-res/ewmidi.html
When I think over the keyboards I've ever owned, I can't remember if any of
them had the ability to turn off the Program Change send.  You may be asking
too much from those overworked synth designers.
Ed Edwards
Leader: Ezekiel's Wheel\ufffd      \ufffd\ufffd\ufffd\ufffdRetro-Progressive Rock\ufffd\ufffd\ufffd\ufffd
http://artists.mp3s.com/artists/227/ezekiels_wheel.html
\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd\ufffd.\ufffd\ufffd
To: <AN1x-list@yahoogroups.com>
Sent: Tuesday, October 16, 2001 8:46 AM
Subject: [AN1x-list] Program change - no thanx?
> Hi!
>   / Mattias
> Community email addresses:
>   Post message: AN1x-list@yahoogroups.com
>   Subscribe:    AN1x-list-subscribe@yahoogroups.com
>   Unsubscribe:  AN1x-list-unsubscribe@yahoogroups.com
>   List owner:   AN1x-list-owner@yahoogroups.com
> Shortcut URL to this page:
>    http://groups.yahoo.com/group/AN1x-list
