Index last updated: 2026-04-03 01:03 UTC
Re: [AN1x-list] GG - PLG150AN on KENTON - CC7 and other things
2001-10-13 by Paul Murphy
GG,
Your hint on using the controller mapping feature of the PLG150AN to map CC7
to VCA Volume is not bad, and I will use it pending a better solution.  It
has a couple of minor drawbacks 1) Sometimes VCA level affects timbre as
well as level and 2) You have to re-send the sysex after every program
change, or program it as part of every patch.
I tried cutting and pasting the SYSEX into a mixer map control for
convenience, but it didnt work.  My solution now has been to map CC7 to my
PULSAR2's big mixer controlling the mixer 's faders on the PLG150AN's
channels.
This works, and Im assuming the output from the PLG150AN is really mono so
cant be panned either.  In this case I will only take the left feed and
teach my PULSAR to pan the mixer channel using CC10.
Another thing I tried was mapping the chorus CC to the PLG150AN's CVO fine
tuning, but for some reason, that mapping is disabled by the matrix - any
thoughts as to why ?
Paul
RE: [AN1x-list] GG - PLG150AN on KENTON - CC7 and other things
2001-10-13 by Gary Gregson
Hi Paul
I am not sure why VCA volume should affect the timbre of the voice?
However you are correct that the matrix must be programmed on a per
voice basis.
The output of the card is actually a stereo signal, but for your
purposes I think you can treat it as mono.
The VCO tuning parameters are exclusively wired for control by Pitch
bend and key tracking I'm afraid, so you can't do what you desire with
the chorus controller :-(
Regards
Gary Gregson
Email:gary@...
http://www.yme.co.uk/yme
Sent: 13 October 2001 09:15
To: AN1x-list@yahoogroups.com
Subject: Re: [AN1x-list] GG - PLG150AN on KENTON - CC7 and other things
GG,
CC7
It
my
channels.
so
fine
any
Paul
