curious midi question
2001-07-13 by beelyle@msn.com
2001-07-13 by Bruce Wahler
>I've had the an1x for about a year. No problems at all, however I amIt's called "active sense" or "running status." Whenever the synth is not
>wondering what sort of midi data the thing is constantly sending?? I
>have a unitor 8 and the an1x is the only device that is causing the
>unitor to constantly flash on it's corresponding midi channel. I
>have flipped thru all submenus, but cannot find the cause. Anyone
>know what this thing is constantly sending, can it be disabled?
>Its not a problem, I am only curious.
2001-07-13 by jondl_2000@yahoo.com
> I've had the an1x for about a year. No problems at all, however Iam
> wondering what sort of midi data the thing is constantly sending??I
> have a unitor 8 and the an1x is the only device that is causing theUnless I'm mistaken, this is the Active Sensing message provided by
2001-07-13 by basile v. vorontsov
>> have a unitor 8 and the an1x is the only device that is causing thejyc> Unless I'm mistaken, this is the Active Sensing message provided by
> Hello,the
> >> unitor to constantly flash on it's corresponding midi channel.I
> >> have flipped thru all submenus, but cannot find the cause.Anyone
> >> know what this thing is constantly sending, can it be disabled?provided by
> jyc> the AN1x. Mine exhibits the same behavior but it's never poseda
> jyc> problem. Don't believe there is a command to disable it. Gary,Bruce,
> jyc> or Reg might know otherwise...No. It's just a handshake message - it's not recorded as a MIDI Note
> By the way, don't you guys have problems with the sequencer memory
> filled away with those messages?
> basile vorontsov
> Senior Software Tester / Integrator / Deployment specialist
> CNet Channel Services (http://www.cnetchannel.com)
> Research & Development Department
> Tel +7.095.967.1202 + 217, 227, or 226
2001-07-15 by Gary Gregson
2001-07-15 by Reggie
>Yes, the message is Active sense....almost all Yamaha keyboards sendDead right, But if you have a Midi Controller between the Keyboard and
>this message. Its part of the MIDI spec and is in general a good idea.
>(If you check the AN1x MIDI implementation chart you will see that the
>message is both transmitted and received by the device)
>No, there is no way to turn it off on the An1x (or at least I don't know
>of any way to disable it ;-(
>I got told something slightly different, From Nick Howes, that VST
>The message is designed for live performance situations, to avoid hung
>notes. For example if someone kicks the MIDI lead out, then the
>receiving device will turn off any sounding notes.
>All sequencers that I am aware of simply consume the message (they do
>not store it or forward it).
>See ya,
>Regards
>Gary Gregson
>Email:gary@...
>http://www.yme.co.uk/yme
>Community email addresses:
> Post message: AN1x-list@yahoogroups.com
> Subscribe: AN1x-list-subscribe@yahoogroups.com
> Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com
> List owner: AN1x-list-owner@yahoogroups.com
>Shortcut URL to this page:
> http://groups.yahoo.com/group/AN1x-list
>Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
