Amod Depth
Amod Depth
2001-06-02 by Dj Cyberspirit ~ Stefaan Vermeulen
Hello Group!
I have another question for you. In the VCA section you have the Amod Depth. This really rocks but... I'm not able to change the speed of that... I always have to set the BPM (of a song) to the speed of the Amod Depth...
Is it possible to change that? If Yes; How can I do that?
THX in advance!
Stefaan
RE: [AN1x-list] Amod Depth
2001-06-02 by Gary Gregson
a song) to the speed of the Amod Depth...Is it possible to change that?
The VCA Amp modulation is provided by LFO1 (if you are using AN1xEdit
and let the mouse hover over a control...a tool-tip will popup to tell
you the source of such modulations ;-)
You can vary the LFO1 speed, and you can get it to retrigger on each
note on.....but you cannot directly sync it to song tempo ;-(
A better way of doing this if you do actually want the modulation synced
to song tempo is to use the FreeEg.
-  Draw a suitable FreeEG track to control <VCA Volume> on the relevant
scene (or scenes).
- Set the <FreeEG Length> parameter to one of the MIDI tempo related
values: e.g. 1/2bar - 8bar.
- Set the <FreeEG> trigger to FREE (unless you want to retrigger on each
note)
- Set the voice <Common Tempo> parameter to MIDI.
Assuming your sequencer is sending MIDI clock to the AN1x, the amp
modulation should now be perfectly synchronised to the song.
(Remember to set your original <VCA Amod depth> to zero unless you want
two sources of amp modulation ;-)
Regards
Gary Gregson
Email:gary@...
http://www.yme.co.uk/yme
