an200/an 150
an200/an 150
2001-04-07 by DMANX@talk21.com
what is the diffrence in features between 150AN plg an the AN200 SOUND MODULE? Can the two be used together?
talk21 your FREE portable and private address on the net at http://www.talk21.com
Re: an200/an 150
2001-04-08 by jondl_2000@yahoo.com
--- In AN1x-list@y..., DMANX@t... wrote:
> Hi,
The PLG150AN board is a 'daughterboard' that requires a host system to
function, i.e., Plugstation, MU90R, SW100XG, CS6x/r, etc.
The AN200 is a PLG150AN-in-a-box, i.e., table top module. The sound
engine is the same but, obviously, the AN200 has a physical user
interface allowing access to key functions. Unless I'm mistaken, I
believe the AN200 is also equipped with a sample sound set in ROM that
is available for use simultaneously making the AN200 a synth/drum
machine combo.
Both products provide different solutions to users needs but are based
on the same same sound engine. Personally, I have to admit I'm eager to
check out the companion DX200 box.
As to whether the PLG150AN and AN200 can be used together - well, that
depends on your existing kit doesn't it? The AN200 doesn't appear to
offer an expansion slot for a 2nd PLG150AN card if that's what you're
thinking of (making it into a 10-voice, table top AN1x.)
HTH,
Jon
