On Mon Aug 29 2005, daniel_8887 <
daniel_8887@...> wrote:
> Hi AN1x Group!
Hi..
> Is there a possibility to disable this f....ng Ribbon Controller on
> the left side?
> I play for a while and then the sound gets like interrupted (short,
> without release) till I press some times the Ribbon (I heard that I
> have to press on the right side-above) and then I can play for a
> while till it comes again. And again, and again....
It sounds more like you have some loose connection causing the ribbon
to always interfere with your whole setup. Check out the the yahoo
webpage of this group for some guides about screwing through your an1x.
> I thought this machine is made for live performance? Pressing always
> the Ribbon like a mad (making brzz, brzzz) to get the sound back????
> How would this look like?
Pure bashing on some technicality... It really sounds like you have a
faulty ribben, because mine doesn't have glitches at all (i'm actually
having trouble assigning it to my patches, but i'm not that far
through the manual yet :P )
> This is an analog synth, where I am never a slave of the sound.
It's actually a digital synth....... Virtual Analog. Some nasty DSP's
and other things pretending it to be a real analog synth. Doing an
amazing job at that. (I.e., all analog circuits are emulated through
dsp's and other processors)
> Playing digital is always being a slave of the sound (played an E4
> for a long time). Digital are boring and straightforward.
> I bought this analog synth to have a grip on the sound. And now
> this :-(
Try to fix it ^_^
> It looks like that some, or one technician made this brzzz, brzzz
> feature intentionally. This is destroying the whole system.
> Thanks in advance for suggestions to stop this unnecessary feature.
> Best Regards,
> Daniel Mandic
> P.S. Sounds better than ANY digital synth.
True that!
Hope to have helped. Haven't unscrewed my AN1x yet, but on the group
pages someone did. He had some loose knobs and faulty ribbon
controller... but some new screws and plugging the ribbon ribbons back
in helped solve those problems.
Really, it just sounds like a technical malfunction. Because the ribbon
controller is just like the pitchbender, modwheel or one of the turn
knobs. It's there to do some mindbending sound tweaking, not to disrupt
the usage of the board (at least not intentionally).
Cheers!
Gerald Raucamp -
cavey@...
http://www.cavey.nl
