AN1x editor/SW1000/VST5 - different patches -how to access
2001-02-07 by andy@wilbya.freeserve.co.uk
Hi all,
I'm getting a bit confused with this AN1x editor, the PLG board and
its use through VST 5.
Firstly, thanks to Reggies patchname scripts I can now access the
default Bank 1 & Bank 2 sounds which is a revelation (never could get
it to work properly before).
Secondly, thanks to some searching of user group files, I have the
setup as recommended by Gary Gregson for AN1x editor/SWG/CubaseV5
using Hubis. The PLG board is running in PLGAN mode, with Part
allocated to 1 and midi channel 1.
Now what I want to do is use the editor to change sounds and then
access these from VST. I know that I mess with the sounds copy and
paste into a separate buffer then can save these to disk. When I
load a bank into the editing screen, do I send all the sounds to the
card using the SEND ALL button?. Do I need to send the system as
well? I've tried this, but not managed to hear the sounds that I'd
edited (sequences etc.). Also I can't seem to audition sounds using
the virtual keyboard.
When I do manage to get sounds onto the board, how do I select them?
Do I have to send MSB LSB numbers and which ones?
Any help greatly appreciated
Andy
RE: [AN1x-list] AN1x editor/SW1000/VST5 - different patches -how to access
2001-02-07 by Gary Gregson
First of all you need to get the virtual on screen keyboard working. If
that's not sounding the PLG150AN or the XG synth...then it is unlikely that
An1xEdit is talking to the synth at all!!!!
Then you need to understand how the AN synth works. Basically on the
PLG150AN you have two preset banks in ROM and a single user bank in RAM
(which you can use An1xEdit to download sounds to). However it doesn't
matter which bank you select a sound from, the synth works the same
way......basically the whole patch is copied into a temporary working area
on the card (the edit buffer). From here you can manipulate the patch in
real time. When you tweak any of the controls with An1xEdit, it is this edit
buffer that the program is working on ....plus when the synth sounds....it
is this buffer that it is using to generate the sound.
So you have two options:
a) you can upload a whole library (or selected voices from a library) to the
user bank of the card. Thereafter you can send the appropriate MSB, LSB,
Prog change commands to select that voice into the synths edit buffer ready
for playing.
OR
b) You can simply select a patch in An1xEdit, and it will automatically load
that patch into the edit buffer ready for playing.
Basically you would use option (a) if you were using several patches in a
song and don't want to have AN1xEdit running. Option (b) is more useful if
you are only using a single patch in the song and want to mess about with it
using An1xEidt.
In either case unless you ensure An1xEdit is talking to the synth...you're
not going to get very far.
Also you have to make sure that the XG synth is correctly configured to use
the PLG board (in place of an XG part)...otherwise you're only ever going to
hear the XG part sound.
Even if the XG synth isn't configured correctly....the keyboard on An1xEdit
should still sound something...if it doesn't then An1xEdit is not talking to
the SW or the PLG. So sort that out first!!!
Thereafter, set up the system area of An1xedit so that it selects the
PLG150AN to replace an XG part (basically set the DEVICE=1, BOARD=1, PART=
the XG part you want to replace, CH = the MIDI channel you want to use (by
default set this to the same number as the part).
Thereafter you should be able to simply select patches in AN1xEdit and play
them from VST or the on screen keyboard. The synth should also respond
appropriately as you tweak An1xEdit controls.
Regards
Gary
Email:
gary@...
http://www.yme.co.uk/yme
