This should be an easy fix, but here's what's going on.
I have a midi clock signal from either cakewalk or my 505 going into
the AN1x. In order to play a sequence on the anx i reduce the midi
tempo switch all the way down until it reads "midi". Now if press
any of the keys the arp or seq I get a single note, but no sequence.
Yes i have the receive channel set to the correct setting, (not that
it should matter for a clock signal)
The only way i can get it to work is by shutting off the power and
restarting. The settings remain, but now i can play a sequence in
time.
Has anyone had this problem? Is there a work around?
Gerry
