Index last updated: 2026-04-03 20:49 UTC
ANbody want a PLG AN Instrument Patch Script for VST 5?
Re: [AN1x-list] ANbody want a PLG AN Instrument Patch Script for VST 5?
2000-12-02 by Paul Murphy
YEAH YOU BET !   I DO    I DO    I DO !!!!!
To: <AN1x-list@egroups.com>
Sent: Sunday, December 03, 2000 5:28 AM
Subject: [AN1x-list] ANbody want a PLG AN Instrument Patch Script for VST 5?
> Well, Do you?
> Reggie
> Community email addresses:
>   Post message: AN1x-list@onelist.com
>   Subscribe:    AN1x-list-subscribe@onelist.com
>   Unsubscribe:  AN1x-list-unsubscribe@onelist.com
>   List owner:   AN1x-list-owner@onelist.com
> Shortcut URL to this page:
>   http://www.onelist.com/community/AN1x-list
Re: [AN1x-list] Re: ANbody want a PLG AN Instrument Patch Script for VST 5?
2000-12-03 by Paul Murphy
It means instead of having to use XGEdit or XGworks to call up an PLGAN
Patch from CUBASE, you get to pick it from a list that appears in CUBASE5.
Should bypass a known problem with CUBASE (sysex data gets truncated when
receiving this patch information from an external program).
Sent: Sunday, December 03, 2000 11:46 AM
Subject: [AN1x-list] Re: ANbody want a PLG AN Instrument Patch Script for
VST 5?
> Hi Reggie,
> Could you please explain a little further?
> Regards,
> Lars
> --- In AN1x-list@egroups.com, Reggie <reggie@t...> wrote:
> > Well, Do you?
> > Reggie
2000-12-03 by Reggie
Hello Lars,
It is a text file that you can use inside VST 5 to get at the preset
sounds on the PLG AN card from the arrange window by voice name. It will
also work for the AN1x Keyboard but the Voice names won't match, but I
will write one for that as well.
In message <90c55v+f2ea@...>, lars.l.arnwald@... writes
>Hi Reggie,
>Regards,
>Lars
>> Well, Do you?
>> Reggie
Reggie
The other way is to use the Multi Client drivers and Hubi's, the use AN-
edit direct to the SW1000 #1 output, XG-edit goes into VST via LB1.
Vst will still glitch when you choose a user patch in AN edit, because
the SW is receiving so much sysex data all in one go, but with my patch
script you will be able to get at the preset voices without glitching,
because the preset Voice data is on board.
In message <000f01c05cc4$1083ea80$0641a4cb@...>
, Paul Murphy <merfman@...> writes
>----- Original Message -----
>From: <lars.l.arnwald@...>
>VST 5?
>> Hi Reggie,
>> Regards,
>> Lars
>> > Well, Do you?
>> > Reggie
Reggie
