How are you currently attempting to perform the patch change?
Are you embedding patch changes in your Cubase song file (either from
inspector or from list view)? If so make sure you include both the relevant
Bank Select and the Program change messages.
If you are manually performing the patch change from An1xEdit...what is your
MIDI port setup (ie.. where is An1xEdit data routed).
Regards
Gary
Email:
gary@...
http://www.yme.co.uk/yme
tuffpro@... [mailto:
tuffpro@...]
Sent: 28 October 2000 10:01
To:
AN1x-list@egroups.com
Subject: [AN1x-list] AN Edit PLG 150 help me!
im using cubase with a SW1000XG(WITH XG EDIT)& a PLG 150 daughter card
(with AN EDIT). My problem is that i cant get cubase to triger more
than one of the PLG 150 sounds. EG Start tune with instrument 1 from
the AN edit list, then use instrument 2 then 6,then 9 then,100 etc.
I know i cant play more than one instrument at a time but im sure you
can play one instrument followed by another, i think i need to use
sys exe messages. How do i do this?
Sombody please help.
