> >suggestion??
I ran across this, though I have forgotten the details. I believe it
has to do with asio 2.0 supporting "vst synthesizers" and asio 1.0
not doing so. I suspect that MDA vocoder may require asio 2.0 that
vst 3.7 may not support (I know for sure that version 3.55 - my
version - does not support asio 2.0 drivers). Hence I can't use any
of the cool new vst plug-ins (yet).
You might check to see if that is the problem. If vst 3.7 supports
asio 2.0, it might be just a question of downloading new asio drivers
for your soundcard.
Hopw this helps,
Jerry
