Replacing AN1x potentiometers with better ones?
2016-05-28 by Matt Gregory
Archive for AN1x-list.
2016-05-29 by Jeff
Hello !
the "stair stepping effect" can be more likely the result of the analog - digital conversion (8 bits = 0 to 255) than "scratchy" pots... First try to clean them with some electronics contact cleaner.
Cheers.
J.F.
> Message du 29/05/16 02:06
> De : "Matt Gregory mgregory22@... [AN1x-list]" <AN1x-list@yahoogroups.com>
> A : AN1x-list@yahoogroups.com
> Copie à :
> Objet : [AN1x] Replacing AN1x potentiometers with better ones?
>> Has anyone here ever replaced the pots on the AN1x with higher quality
> ones to get rid of some of the stair-stepping effect that happens
> while you're editing? I was comparing my AN1x with a Roland GAIA and
> the GAIA knobs are so much smoother sounding and better feeling. And I
> was noticing that the AN1x knobs are capable of hitting every value in
> the sweep, but you really have to go slow and be careful, otherwise it
> will skip a lot. I think higher quality pots would help tremendously
> and it would be a cool little upgrade for the AN1x.
> Matt
2016-05-29 by Peter Korsten
> Has anyone here ever replaced the pots on the AN1x with higher qualityBear in mind that the AN1x quite likely only transmits 8 bits of data
2016-05-29 by michael@inoutflux.dk
By pressing Down in The pots the respond in smaller increments.
------ Original message------
Date: Sun, 29 May 2016 09:50
To: AN1x-list@yahoogroups.com;
Subject:re: [AN1x] Replacing AN1x potentiometers with better ones?
Hello !
Cheers.
J.F.
> De : "Matt Gregory mgregory22@... [AN1x-list]" < a="">><>
> Copie à :
> Matt
2016-05-29 by Bruno
Op 29-5-2016 om 01:11 schreef Matt Gregory mgregory22@... [AN1x-list]:
for the pots, which gives you 256 discrete values. These can easily be
heard. On the other hand, it understands more resolution via MIDI
(probably 16 bits or 16536 values) which sounds much smoother. No idea
if this is the case with the Gaia, but it could be.
- Peter
Posted by: Peter Korsten <peter@...>
Community email addresses:
Post message: AN1x-list@yahoogroups.com
Subscribe: AN1x-list-subscribe@yahoogroups.com
Unsubscribe: AN1x-list-unsubscribe@yahoogroups.com
List owner: AN1x-list-owner@yahoogroups.com
Shortcut URL to this page:
http://groups.yahoo.com/group/AN1x-list
Yahoo Groups Links
<*> To visit your group on the web, go to:
http://groups.yahoo.com/group/AN1x-list/
<*> Your email settings:
Individual Email | Traditional
<*> To change settings online go to:
http://groups.yahoo.com/group/AN1x-list/join
(Yahoo! ID required)
AN1x-list-digest@yahoogroups.com
AN1x-list-fullfeatured@yahoogroups.com
<*> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo Groups is subject to:
https://info.yahoo.com/legal/us/yahoo/utos/terms/
2016-05-29 by Bruno
I'd risk a statement, that it has much more to do with the way the software reacts to the knob movements...2016-05-29 11:05 GMT+02:00 Peter Korsten peter@... [AN1x-list] <AN1x-list@yahoogroups.com>:Op 29-5-2016 om 01:11 schreef Matt Gregory mgregory22@... [AN1x-list]:
- Peter
Yahoo Groups Links
2016-05-29 by Matt Gregory
On Sun, May 29, 2016 at 3:50 AM, Jeff jf.serviere@... [AN1x-list] <AN1x-list@yahoogroups.com> wrote:Hello !
Cheers.
J.F.
> Copie à :
> Matt
On Sun, May 29, 2016 at 5:05 AM, Peter Korsten peter@... [AN1x-list] <AN1x-list@yahoogroups.com> wrote:Op 29-5-2016 om 01:11 schreef Matt Gregory mgregory22@... [AN1x-list]:
- PeterWell even if it could receive a wider range of values, most of the parameters only have 7 bits, so there are only 128 different values. But I really think my biggest problem is that my pots are being insensitive. They could be sticking from being dirty, but they've had this problem for as long as I can remember. I'm going to try cleaning them and see how that goes. I'll keep you guys posted.Matt
2016-05-29 by jim.alciere@...
2016-05-29 by Jeff
Better on my Telecaster...
Regards.
J.F.
> Message du 29/05/16 16:47
> De : "jim.alciere@... [AN1x-list]" <AN1x-list@yahoogroups.com>
> Copie à :
> Objet : Re: [AN1x] Replacing AN1x potentiometers with better ones?
>> Replace the knobs while you're at it.
2016-06-01 by jim.alciere@...
2016-06-01 by Sean King
On Sat, May 28, 2016 at 7:11 PM, Matt Gregory mgregory22@... [AN1x-list] <AN1x-list@yahoogroups.com> wrote:Has anyone here ever replaced the pots on the AN1x with higher quality
Matt
