Low volume output
2014-01-17 by <william.bromell@...>
When connected to my interface (line level inputs), I have to boost AN1x by around 6 - 12 dB in order to get a strong signal. (I do this in Ableton, not via preamp for obvious reasons.) This is with the volume knob all the way up, including both factory patches and my own. The interface only accepts XLR, so I've got TS to XLR cables (I'm told this is better than using balanced cables to connect unbalanced gear).
Any ideas? I've heard the power supply might be the issue.
