Archive for AN1x-list.
MIDI Load Error?? London Set
2013-10-28 by <xenteq@...>
Hi, hope someone can help.  I'm trying to load the London Set MIDI file using Cubase LE 4 and keep getting 'Sys Ex Size Error'...
Does anyone have this set in .AN1 format?  I have looked on the files area of the group and couldn't see it.
Re: MIDI Load Error?? London Set
2013-11-02 by chris22443366
I sent you an email with the set attached in .AN1 format. Hope you get them ok.
Cheers
Chris
> Thanks
2013-11-02 by derek192603
Have you tried opening and "playing" the file to the AN1x using Windows Media Player? It's lo-tech approach can work on doing MIDI based transfers when the heavyweights fail
I think MIDIOX (http://www.midiox.com/) will play MIDI files as well.
My an.factory librarian (http://www.xfactory-librarians.co.uk/) can (once registered) load AN1x files in any format and then save in any format or send to the AN1x
Finally, as per request, I found a copy in AN1 format and have uploaded it to the AN1x section of the Files area.
HTH
Cheers
Derek
> Thanks
RE: MIDI Load Error?? London Set
2013-12-14 by <xenteq@...>
Chris, Derek,
Thanks for both your responses.  Much appreciated.  The set loaded fine using .an1 file.
Cheers,
Dan
