About OFFSET\GAIN resistors inside
2012-10-17 by digital_plain
Archive for AN1x-list.
2012-10-17 by jammie
To: AN1x-list@yahoogroups.com
Sent: Wednesday, October 17, 2012 1:53 PM
Subject: [AN1x] About OFFSET\GAIN resistors inside
Hi guys! Can anyone tell me what this two resistors are - "gain" and "offset" on the keyb. board inside the synth? I'm going to make some service like replacing the battery and some capacitors, and just found this additional features.
2012-10-17 by j k
Sent: Wednesday, October 17, 2012 6:33:47 AM
Subject: Re: [AN1x] About OFFSET\GAIN resistors inside
its for the aftertouch
its for changing the sensitivety to the players liking
as its factory set as a standard but some pleople press softly other hard
but if your pressing it so hard that it feals like the keys are going to snap then adjust until you get the pressure you want
2012-10-17 by Jeff
Sent: Wednesday, October 17, 2012 5:31 PM
Has anyone tried replacing these resistors with some thing variable so that aftertouch can be re-adjusted if necessary or would it be more like a resistor swap which would then redefine aftertouch based on the resistors you replace them with. Anyone done this? I'm finding the aftertouch way too sensitive -- its almost like all or nothing with very little expression in between with my playing (albeit horrible) style.
2012-10-17 by j k
Sent: Wednesday, October 17, 2012 3:34:30 PM
reduce the gain
and they sould be trimmers
its the same after touch board as used by dx7 and all yamaha and most korgs
2012-10-18 by Jeff
> reduce the gain
> korgs
> From: j k
> To: AN1x-list@yahoogroups.com <mailto:AN1x-list%40yahoogroups.com>
> From: "jammie" <jammie.emma@...
> <mailto:jammie.emma%40blueyonder.co.uk>>
> From: digital_plain
2012-10-18 by digital_plain
