Parts and Ribbon Controller
2012-07-08 by ubergvx
I posted back on June 5 (message #12648) about trying to fix my defective ribbon, and then trying to order just the ribbon sensor, and then having to order the entire ribbon controller assembly (part #part #VY664600) from Yamaha 24-7 (https://www.yamaha24x7.com/YamahaOMS/BasePages/Login.aspx?ReturnUrl=%2fyamahaoms%2fdefault.aspx).
The part arrived a couple of weeks ago but I just got around to installing it. It doesn't include the metal backing plate for the ribbon sensor, and the old sensor was attached to that metal plate with some kind of adhesive. I tried to pry it off very carefully in hopes that I could re-use the existing adhesive. That *sort of* worked; there was enough sticky stuff left on the plate to attach the new ribbon sensor, but some of it had peeled off, so the surface of the ribbon is a little bit lumpy.
The slight lumpiness doesn't bother my fingertip, and the ribbon is working just fine. I do wonder if my hack installation - and resulting lumpy backing for the ribbon - means that it'll go bad again. Time will tell. ;-)
Next time - if there is one - I'll scrape off all the old adhesive and then try to find a new adhesive for the new ribbon. Installation of the new circuit board was also a little tricky due to the location of the screws, but was otherwise straightforward (if you don't count all of the usual screwing/unscrewing just to get the synth open & clossed in the first place!).
Sorry to say that Yamaha 24-7 is only for US customers, and I couldn't find an international support site with similar parts availability. If someone out there knows of such a site in your own country, others on this site would probably like to hear about it.
Van
Van
