Index last updated: 2026-03-31 01:25 UTC
CTRLR and Ableton Live for AN200/AN1x
2012-04-03 by dan
Hi, i have tried so many times but it seems impossible to use CTRLR in Live 8.
Someone had better luck?
Maybe it's a setup issue...
Re: [AN1x] CTRLR and Ableton Live for AN200/AN1x
2012-04-03 by Eanna Butler
Does the ctrlr editor for the an1x send sysex or nrpn, or does it send cc?
Ableton actively filters out sysex... Have you tried another vst host?
Reaper does sysex, might be worth a shot...
8.
Re: CTRLR and Ableton Live for AN200/AN1x
2012-04-04 by dan
Maybe you're right, the sysex filter can be the problem.
So i would like to build a simple vst CTRLR plugin with CCs only to automate AN200 within Live.
Can someone point me in the direction on how to do it?
Even if i try to put the CC number in Live midi track, drawing the automation curve for cutoff (cc74), i got a bad response from the synth: a kind of slow-motion output.
Would be great to have from someone a little help on better automation in Live with our Yamaha synth.
2012-04-04 by ikstation7
So for me it works. Its a little bit complicate to explain for me in english. German woult be easyer but i will try. I list single steps sure that you know most of them. But this way was for me successful.
Put the VST CTRLR in a MIDI Track. Inside open Device Data Base. Click on refresh. Scroll down to the anx1 panel.On the right side click download this item. Goto open Panel C:\Users\USERNAME\Documents.
Then goto Midi device Settings. Be sure that MIDI in and out is turned off in Live. Then in Ctrlr go to Panel Edit Mode. On the right edit the Midi input and output. You have to check the box 1. Panel wants VST input 2. Midi thru. Again click on Panel Edit Mode. Now in Live click on Configure turn a few knobs in Ctrlr now you have slider in live.Again click on Configure. In the Arrangment view record a few slider movments. So for me it works this way.
If you want to write/build your own Ctrlr Sysex string must be set correct.
Hope this helps
Sven
2012-04-04 by Eanna Butler
Completely agree with you - integration of synths with software is fraught,
and there really should not be a reason for that at all.
Unfortunately, I've sold my AN200, but have stayed on this List because
it's such a thread of positivity!
I have some other synths, and have promised myself to figure out exactly
what the issues are with automation - is there a common theme? What are the
variances (VST Host, Midi Interface, Synth, CC/NRPN/Sysex - a matrix of
options)? It'll be a technology-focussed evening rather than a musical one
in my bijou project studio.....
Are you using an External Instrument device in Ableton? Can you record CC
movements from the front panel of your AN1X along with midi note data
(regardless of CTRLR)? What happens when you play that back - same 'slow'
behaviour? Are you using something like a Midi Merge box, or a Midi
Patchbay, in between your Midi interface and the Synth?
Make sure you synth is setup to transmit CC from the front panel, and that
you've followed the Yamaha documentation around this.
Then try Reaper! ;-)
Good luck.
EBu
Re: [AN1x] Re: CTRLR and Ableton Live for AN200/AN1x
2012-04-04 by jammie
you should not need ctrlr as its prity rubbish its all geuss work as theres no proper documentation
its all ill try this and see if it works
with ambleton use use the source max for live you can do anything with it if you can think it and draw it you can make it and a controler for it
its very easy and theres plenty of help files and examples to show you how to do it
ive used it to make little wavetable controls of basicsounds so that it sweeps through the wavetable and becuase its osc compatible you can create custom touch oscpanels
To: AN1x-list@yahoogroups.com
Sent: Wednesday, April 04, 2012 5:25 PM
Subject: [AN1x] Re: CTRLR and Ableton Live for AN200/AN1x
Good luck.
EBu
2012-04-05 by ikstation7
Hey you cant compare these two products !! If you not able to use it you dont have to!! Dont flame against Ctrlr only because you can not figure out how to use it !!! ATOM working for years on this its only one guy and its totaly free !! Max for live fore sure is a good programm but you have to pay 200 Euro. And i buy it only to see that nobody can realy help u with Sysex !!! This works on Ctrlr out of the box......
> From: Eanna Butler
> Hi,
> Good luck.
> EBu
2012-04-05 by jammie
i have an opinion and im intitled to it
yes i under stand 1 guy did it
but you can do the same in any sysex editor
i have been doing it for years with sound diver
sysex is old if you want to know about sysex then learn hex
its an old system so you need to look up old files
best way to learn is 8bit cpu programming as its all done in hex
or get a mirage sampler as all its functions are done in hex
and if you are an old fart like me who got brought up 8 bit micros
and was around when they first started to impliment it
and if your not interested in what i have to say then dont read
Sent: Thursday, April 05, 2012 5:16 AM
> From: Eanna Butler
> Hi,
> Good luck.
> EBu
2012-04-06 by ikstation7
So I agree with you in most of the points.
Fore sure sound diver and i.e. AN1X Editor ...they all can handle Sysex.
But in Ableton Live there is one Bug: it Filter the Sysex data from external Keyboards. Everything you can change with CC is no problem. But it simply ignore changes via Sysex and you cant record knob movments.
Because they use it for internal stuff and to the speech with external Hardware Controller.
So you must have an "virtual Cable" to use it.
Ctrlr is one and an easy to use way to avoid the Problem.
Max for Live can handle sysex data for sure.
You have to use java and get an "cable" to MaxMSP. Then it works.
But there is no way to do this out of the box.
So Ctrlr can be very helpful if you unfamiliar with sysex data and a solution with the live bug.
I hope i have convince you that in this specific case its not rubbish.
> From: ikstation7
> > From: Eanna Butler
> > Hi,
> > Good luck.
> > EBu
2012-04-06 by dan
Ehy guys, thanks!
@Sven: i will try what you told to make CTRLr work. I hope AN1x panel will work for my An200 too.
On programming: i would like to try a simple CTRLR vst panel only with CCs, to automate those parameters in Live, but i don't know how to do it. It should be easy: a panel with 15 CC knobs and no more. If someone could help me it would be great.
On synth slow-motion during automation: i really don't know the cause. I disconnected my midi thru box but the result it's the same.
My AN200 seems to receive too much information, but i tink there's no midi loop... Will check better.
I have an AN1X ( no AN200), and there is an option for local on and off. Maybe you got problems when the message of the cotroller comes twice local and with a delay via midi. Maybe i am wrong ...
--- In AN1x-list@yahoogroups.com, "dan" <danielesamas@...> wrote:
> Ehy guys, thanks!
2012-04-06 by jammie
im not saying it is rubbish it does work
but not having any manual on how to use it makes it rubbish for people who are trying to figure it out and cant get it to work
i dont have a problem with it but im used to the atari days so if you wanted something to work you wrote it so that it did work
and i like sounddiver been using it for years
but the problem realy lives with ambleton and people should petition them not to filter the events out for when you ar recording such messges for control of your said synth
im all for nice helpfull apps and free ones are better as they cost nothing
but for better developement and a good written manual the creator could charge for the manual as it takes lots of time in programing and expalining in text how todo things and it would help in creating more panels as people could take on the chalange
Sent: Friday, April 06, 2012 7:24 AM
> From: ikstation7
> > From: Eanna Butler
> > Hi,
> > Good luck.
> > EBu
any way the an1x you can set it to send and to respond to cc so why are you sending sysex data for control
sysex dumping really is good for dumping whole banks of patches or sequences
but if you are sending real time control mesages via sysex then thats why automation is going to slow down as sysex data is larger streams than cc and you could be overloading the uart with sysex data
and usualy with sysex data realtime control if you have a key pressed for a long time and use sysex to change the filter cutoff
it wont change until you re press key most of the time
Sent: Friday, April 06, 2012 11:35 PM
Subject: Re: [AN1x] Re: CTRLR and Ableton Live for AN200/AN1x
> From: ikstation7
> > From: Eanna Butler
> > Hi,
> > Good luck.
> > EBu
