AN1x editor for Ctrlr (OS X & Windows)
2011-10-29 by Zach Archer
Archive for AN1x-list.
2011-10-29 by Nate King
2011-10-29 by thedlovas
--- In AN1x-list@yahoogroups.com, Nate King <nate@...> wrote:
> awesome! anyone that uses ctrlr gets my respect (i love that thing! :) ).
> between that and midi touch the software world is really moving ahead. I'll
> definitely check it out and be happy to provide constructive criticism.
> Thanks for sharing,
> Nate
2011-10-30 by jondl_2000
>This looks very cool and it's kind of you to share your efforts.
> Hello, I created an AN1x editor this evening, using Ctrlr. It's ugly
> and lumpy, but it works pretty well! Here's the link:
> http://ctrlr.org/viewtopic.php?f=61&t=759
> Some features aren't implemented yet (there's no way to edit Scene 2,
> or the VarFX, etc)... If this editor is useful, then let me know what
> features you'd like to have added. Thanks --
> -- Zach
> 503.481.6338
> zacharcher.com
2011-11-01 by marcus gaudio
2011-11-01 by zkarcher
> > -- Zach
> > 503.481.6338
> > zacharcher.com
> . Will read up on Ctrlr and give this a try - looks like a beautified Logic Environment :-)
> Jon
2011-11-01 by thedlovas
--- In AN1x-list@yahoogroups.com, "zkarcher" <zkarcher@...> wrote:
> Thanks! I want to design a nice skin for it, I'll start that when I get a free moment...
> -- Zach
> > > -- Zach
> > > 503.481.6338
> > > zacharcher.com
> > Jon
2011-11-02 by zkarcher
--- In AN1x-list@yahoogroups.com, "thedlovas" <dlovas.monster@...> wrote:
> truly its great!! do you mind if i share this to the guys on vintagesynth.com?
--- In AN1x-list@yahoogroups.com, marcus gaudio <sucramgaudio@...> wrote:
> cool!
> does this works for the an200 also?
> thanks
2011-11-02 by dan
2011-11-03 by dan
2011-11-03 by zkarcher
--- In AN1x-list@yahoogroups.com, "dan" <danielesamas@...> wrote:
> Hi Zack, could you tell me how to use Ctrlr? I can't figure out....
> I got the grid under the knobs and the program seems to be in edit mode, not in "play" mode.
> thanks
> dan
2011-11-04 by dan
2011-11-06 by thedlovas
> If you see the grid, click the "Mode" button. On my screen, this is in the horizontal toolbar on the bottom. It should change to performance mode.
> You might need to change MIDI Input Device & MIDI Output Device, too. These are in the big list of properties on the right-hand side, in edit mode.
> And... If you have a "Devices" icon in the top toolbar, click that, and make sure that your MIDI devices are available.
> I agree that the Ctrlr interface is pretty confusing! Hopefully this will get ironed out in future versions...
> -- Zach
> zacharcher.com
> > thanks
> > dan
2011-11-06 by Nate King
On Nov 6, 2011 12:55 PM, "thedlovas" <dlovas.monster@...> wrote:
> Hey Zach! Once again i wish to tell you that i find your editor to be very
> useful and quite the accomplishment - however i was wondering if you know
> how i can automate the parameters from within the Ctrlr vst plugin? thanks!
> mode.
> > -- Zach
> > zacharcher.com
> > > thanks
> > > dan
2011-11-07 by zkarcher
> Yes, all ctrlr vst knobs are able to be automated AFAIK.
> Ctrlr is a beautiful thing :)
> > mode.
> > > -- Zach
> > > zacharcher.com
> > > > thanks
> > > > dan
2011-11-09 by dan
2011-11-11 by zkarcher
> Hi Zach, do you think it's possible to me to modify your version of Ctrlr AN1x to make it AN200 compatible?
> Of course i need your help to know which parameters to modify.
> Let me know
> dan
2011-11-12 by jondl_2000
> I hope it's possible. I looked at the MIDI specifications for the AN1x, and AN200... I'm confused because the SysEx commands looked >the same<. ... Maybe I read it wrong?
> I'll take another look tomorrow, I have to pass out now!
> When you turn a knob in Ctrlr, does the AN200 show a message?
> -- Zach
> zacharcher.com
> > Let me know
> > dan
2011-11-12 by zkarcher
> If memory serves, the SysEx ID of the AN200 differs from the AN1x. Check the Help File of AN1x-edit - I think there were some particulars listed for each of the AN1x, AN200, PLG-150AN
> Jon
> > -- Zach
> > zacharcher.com
> > > Let me know
> > > dan
2011-11-12 by dan
> When you turn a knob in Ctrlr, does the AN200 show a message?no, no response at all.
2011-11-12 by twobeelandscape
> Jon
> > -- Zach
> > zacharcher.com
> > > Let me know
> > > dan
2011-11-12 by dan
2011-11-13 by jondl_2000
> Hi Zach, just tried the new panel. It does not work, but now i got some midi activity.
> Here's what i found if i turn the AN200 knobs:
> NO RESPONSE of midi activity from:
> FEG sustain
> FEG release
> AEG sustain
> VCO 1/2
> FM DEPTH
> SYNC PITCH
> NOISE LEVEL
> EFFECT PARAM
> SCENE
> VOLUME
> INPUT MONITOR MIDI ACTIVITY OK from:
> LFO SPEED
> FEG ATTACK
> FEG DECAY
> EFFECT WET
> PORTAMENTO
> CUTOFF
> RESONANCE
> FEG DEPTH
> If i move CTRLR knobs i don't have any message from AN200, no midi activity too.
> hope it helps.
> dan
2011-11-13 by Sobaboy
On 12/11/2011 3:59 AM, twobeelandscape wrote:
> Zach/Dan
> The best reference I have found for the differences between AN1X and
> PLG150-AN/AN200 is here, which copies from another (now missing) thread
> by someone called jondl_2000 [:)]
> http://www.synthforum.nl/forums/showthread.php?t=114686
> <http://www.synthforum.nl/forums/showthread.php?t=114686>
> Key differences for voice editing:
> 1. The major additions to AN for the PLG150-AN is the introduction of
> the VCO cross modulation algorithm and new oscillator wave forms
> (Multisaw, Triangle, Sinewave.)
> 2. The AN1x second Scene is not available on PLG150AN. This will not
> affect most AN1x voices, as it is common for only a single Scene to be
> used (the second scene providing a variation for morphing or
> accompaniment). Note that Scene morphing can be replicated by creating
> two voices from the original AN1x voice, each containing one of the
> original scenes. Thereafter store these as two separate voices on the
> PLG150-AN and use the program scene morph feature of the PLG150-AN
> device.
> 3. Layer/Split Modes - the PLG150-AN only supports Single and Unison
> mode.
> 4. Effects - The PLG150-AN only provides AMP SIM variation effect and
> EQ. If the original AN1x effects are important to the voice they must be
> recreated using the effects unit of the host device (e.g. CS6x,
> SW1000XG, MU100, MU128, S80 etc).
> So the main difference in a voice editor would be item 1 (VCO mod/wave),
> with the others subject to their importance to you.
> Hope that helps
> Bill
2011-11-15 by Sobaboy
> FEG sustain
> FEG release
> AEG sustain
> VCO 1/2
> FM DEPTH
> SYNC PITCH
> NOISE LEVEL
> EFFECT PARAM
> SCENE
> VOLUME
> LFO SPEED
> FEG ATTACK
> FEG DECAY
> EFFECT WET
> PORTAMENTO
> CUTOFF
> RESONANCE
> FEG DEPTH
> hope it helps.
> dan
2011-11-15 by dan
2011-11-15 by marcus gaudio
On 15/11/2011 5:41 AM, dan wrote:
> Hi Sobaboy, sorry for what i said before because it works!
> (little mistake of mine...)
> I have not tried all the knobs, but my AN200 responds to the commands with regular midi activity.
> Would be great if CTRLR could change its parameters according to AN200 knobs movement in both directions. Is this possible?
> dan
2011-11-15 by jondl_2000
> guys i misssed something
> where is the an1x editor? is it in the files section of the groups?
> thanx
> Da: dan <danielesamas@...>
> A: AN1x-list@yahoogroups.com
> Inviato: Martedì 15 Novembre 2011 11:41
> Oggetto: [AN1x] Re: AN1x editor for Ctrlr - AN200 Version
> Â
> dan
2011-11-16 by zkarcher
> Yes, it can be downloaded from the Files section of AN1x-list at Yahoo! Groups:
> http://launch.groups.yahoo.com/group/AN1x-list/files
> Look in the Windows and Macintosh directories. The Mac version requires Mac OS Classic, won't run under Leopard or Lion. the Windows version installs under Win 7 and seems to be okay, but I've not MIDI'ed it up to an AN1x proper.
> > thanx
> > Da: dan <danielesamas@>
> > Â
> > dan
2011-11-16 by marcus gaudio
> thanx
> Â
> dan
2011-11-21 by dan
2011-11-21 by Eanna Butler
On Mon, Nov 21, 2011 at 10:19 AM, dan <danielesamas@...> wrote:
> I'm wondering if it's possible to automate ALL the parameters in Ctrlr
> AN1x/An200 panel in Ableton Live, not just CCs, using it as VST.
> Maybe it's the goal of the software but i would like to know if anyone has
> tried it, because in my experience with Live 8 + AN200 only i noticed that
> it is impossible. The automation go crazy and i must turn off the synth.
> Maybe with a software like Ctrlr as bridge would be possible.
> let me know. dan
EBu
2011-11-23 by dan
2011-11-28 by Eanna Butler
On Wed, Nov 23, 2011 at 9:42 AM, dan <danielesamas@...> wrote:
> Ehy Eanna! Veri useful informations, thanks.
> Maybe i made a mistake with midi connections and the data sent to the
> synth were too many to handle.
> I would like to know if Reaper's sysex automation is easy as editing a cc
> curve in Ableton or it requires some difficult setting.
> Dan
EBu
