Re: [AN1x] richy
2010-05-07 by richardon
Hi Jeff
Ah, you like more special, dirty sounds like the mellotron. Do you know the Yamaha CS80 ? Here you can download a demo Version :
http://www.arturia.com/evolution/en/products/cs-80v/intro.html
Pictures of AN1X Waves do not look like Monomoog but like CS80. Its an CS clone. But escpecially the 24 dB Filter is different from CS80. CS80 Filter is producing two Formants combs if resonance is set to maximum. The reason it can sound so vocal.
But if you chose An1X Feedback to 85 or 92 and Hi-pass about 50-70 AN1X 24 dB filter will change dramatically an will produce a similar charakter. But be careful with that and reduce Amplitude if you try it.
Greetings
Greetings
To: AN1x-list@yahoogroups.com
Sent: Thursday, May 05, 2011 11:34 PM
Subject: Re: [AN1x] richy
Hello !
i've tried your patches, some are amazing !
the nr 2 mellotron sounds very close to the motion picture "The song
remains the same" soundtrack
with the 22 you can play a reasonable imitation of the final part of
Yes' "Gates of Delirium". Not the same, because the solo synth is dubbed
by Steve Howe playing a pedal steel guitar , but i think Rick Wakeman
would be happy with "Diamonds" if his fellow was on strike...
Some prog-rock stuff, thanks !
Cheerzs.
J.F.
richardon a écrit :
> Hi Jeff
>> You have a job in electronics engineering ?
> Yes i studied electronics and sound engineering.
>> grab an oscilloscope to look at the waveforms ...
> You can use your soundcard for this and will be totally surprised what kind of Init Waveforms An1X is producing. Without feedback only peaks. Therefore the fundamental waves are damped.
> Around feedback=30 you get the signal spectrum of the mathematic functions. But you won't see that, because the overtones are typical yamaha out of phase. But in www you get Spectral
> analysers for free. Thin Waves with damped fundamentals or signal Generator functions produce a modern Sound, but sometimes you like it more musically like a minimoog. Look at minimoogs waveforms, There is a sine Wave added. The fundamentales emphased.
> An1X is a great machine . He can even produce this with the feedback function.
> With a spectral analyzer you will see it best.
> It must be an accident, that presest sounds were programmed with feedback set to zero.
> Of course this thin sounds are modern. But AN1X is a CS80 clone, vintage.
>> sometimes emulations of "traditional" instruments can be very useful.
> Yes, and if you programm e.g. the breath of a flute seperate you can controle it better than a
> Rom player can do. Roland D50 had an little VA machine. So AN1x is able to produce D50
> sounds. Only the spectral functions must be emulated via FM/Sync. Its also an interesting
> execise to emulate other synthesizers. AN1X can do this with its feedback edge functions
> very well.
> Its Filter changes with feedback too and is very vocal. Together with FX/SYNC, Dely as Comb Filter and breath spectrals he can produce very authentic vocals. I hope so :-)
> And he can spaek more words than "we all die". The AN1x fun examples show this. And of course he can even speak more words.
> Of cause i like this crazy AN1X sounds too. Some examples in this group are really great.
> EG this Atari emulations and of course JayB's great tecno Sounds. Aggressor and Accelerate
> for example. Thats great work.
> I have a question. If i upload my sounds to the yahoo An1x group. Can i change them in future ?
> I want to keep them up to date.
> Ciao, au revoir
> richy
> Sorry my bad english
> Nice sounds
> From: Jeff
> Sent: Wednesday, May 04, 2011 10:30 PM
> Welcome !
> very impressive theoretical work : grab an oscilloscope to look at the
> waveforms ... You have a job in electronics engineering ?
> Nice sounds totraditional" instruments o, sometimes emulations of "can
> be very useful.
> Cheers.
> J.F.
> richardon a écrit :
> > Hi
> > My name is richy an i live in Karlsruhe /Germany. I am new in AN1x Group.
> > Thank you for the lot of sounds that can be found here. Wow great stuff !
> > I own the An1X since 1996. A great flexible synthesizer. But in the beginning
> > i had some problems to understand and programm it in all details.
> > E.g. I didnt knew, that the AN1X only produces thin Pulswaveforms,if FEEDBACK ist
> > set to zero. So i didn't use it for a while on stage.
> > To get the parameters FEEDBACK and EDGE under controle i started to emulate waveforms
> > of other synthesizers on AN1X. Using an Oszilloscope, Spectral Analyzer and my ears.
> > BTW: AN1x never produces straight Wavepictures like SAW or REC. Because overtones
> > are out of phase. So you have to use a Spectral Analyzer or your ears.
> > Some results of this work. Perhaps the list is useful for you.
> > http://home.arcor.de/richardon/2011/an1x_waves.txt
> > (My sounds file contains some templates for feedback and edge parameters)
> > Next step I created some tuned FM sprectrals to emulate D50 Sounds.Spectrals are also
> > useful for Voices, Flute Breath, Melotron, Arco Strings and so on. The PEG can be
> > used as second polyphonic AEG or FEG in such spectral sounds.Thats good, because
> > LFO and EG are not polyphonic. Controling PWM via PEG you have for all waves a simple
> > second polyphonic AEG.
> > Of course for Organs its better to use the Free EG for typical B3 Legato Pecussion.
> > I used another PW Trick in my Organ Sounds to get 888 up to Full Drawbars plus Legato
> > B3 Percussion and Keyclick in one Scene. Template was my old and new CX3.
> > Now her are my sounds :
> > http://home.arcor.de/richardon/2011/richy_5_11.an1
> > I tried to opimize my sounds for stage, therefore they are more traditionell.
> > For example I like to play the Vibraphone Sound during Dinner Music Gigs.
> > An1x can do this as good as a rompler machine. A simple sound, but it was a lot
> > of work to create it exactly like the template. With some classical Drum machines,
> > left hand base you can even play Jazz Standards on AN1x :-)
> > Hope you like it. Dont wonder about some delay settings e.g. in mellotron or
> > vocal sounds. The Delay FX can also be used as an "Comb Filter"
> > Very good to emphasis Formants or simulate Phase Errors of older Instruments.
> > With best regards
> > Thomas Richardon
> > [Non-text portions of this message have been removed]
