an.factory 2.1
an.factory 2.1
2011-01-16 by derek192603
an.factory has been updated to support two AN devices at the same time (I have an AN1x and PLG150-AN) and to support PLG150-AN and the AN200, including AN200 songs.
The program will automatically convert the different voice types between files, or automatically when you send voices to a synth and conversion is required.
There are plenty of other new features as well, including a library bulk importer.
And an.factory works on both PC and MAC OSX.
Now I've completed this work, once I've done some updates for some of the other librarians that I do (I'm currently adding SY99 support to sy.factory), I will be doing the final part of the jigsaw, which is editors, and I'll probably be doing the AN1x and FS1R first (probably the FS1R as that is a pig to program from the front panel!).
You can check out the new release at wwww.xfactory-librarians.co.uk
Cheers
Derek
Re: [AN1x] an.factory 2.1
2011-01-16 by Jhonnie Kratong
Hi Derek!
Your link doesn't work for me.
Any ideas ?
J.
2011/1/16 derek192603 <dacook.sa432bb@...>
> Hi,
> required.
> importer.
> Cheers
> Derek
Re: an.factory 2.1
2011-01-17 by jondl_2000
--- In AN1x-list@yahoogroups.com, "derek192603" <dacook.sa432bb@...> wrote:
> Hi,
> Cheers
> Derek
Props Derek - I'm certain it was quite an effort and I hope you know it's appreciated.
Jon
Re: an.factory 2.1
2011-01-17 by derek192603
Thanks, Jon
It was quite an effort, but as well as music, I find that programming keeps the old grey matter ticking over. :-)
Kudos also needs to go to Renato Navarrete who helped me check the program out with an AN200. Thanks, Renato!
Cheers
Derek
> Jon
2011-01-18 by synergeezer
If you're referring to the X-factory link, remove one of the 4 'w's.
If you're referring to the Yamaha manuals link, keep trying.
- synergeezer
--- In AN1x-list@yahoogroups.com, Jhonnie Kratong <kratong.jhonnie@...> wrote:
> Hi Derek!
> Any ideas ?
> J.
> > Hi,
> > required.
> > importer.
> > Cheers
> > Derek
2011-01-18 by Jhonnie Kratong
Yes , I've realized it a bit later :) (4w)
Thanx , synergeezer
2011/1/18 synergeezer <synergeezer@...>
> - synergeezer
> --- In AN1x-list@yahoogroups.com <AN1x-list%40yahoogroups.com>, Jhonnie
> > Hi Derek!
> > Any ideas ?
> > J.
2011-01-18 by derek192603
Sorry, too many w's!
Cheers
Derek
> Hi Derek!
> Any ideas ?
> J.
> > Hi,
> > required.
> > importer.
> > Cheers
> > Derek
