Very weird problem with MAudio Fast Track
2010-12-29 by solaristica01
2010-12-29 by Nathanael King
On Tue, Dec 28, 2010 at 11:21 PM, solaristica01 <solaristica01@...>wrote:
> Recently I can only hear the AN1X through my Maudio Fast track interface if
> both delay, or the dry+wet values are raised all the way up in the synth.
> it is the weirdest thing. The synth sounds great through its stereo
> outputs, and headphones, it is just through the MAudio... The signal is so
> low, and weird... It will only work with the delay all the way up...
> Any one has any idea what is up with that?
> Thanks very much.
> V.
2010-12-31 by solaristica01
--- In AN1x-list@yahoogroups.com, Nathanael King <nate@...> wrote:
> "it'll only work the the delay all the way up" seems like some sort of
> strange latency issue with the fast track. have you tried other instruments
> through the fast track and do they work properly? I have a mobilepre i use
> all the time without glaring error.
> n a t e
> > Thanks very much.
> > V.
2011-01-01 by Nathanael King
On Dec 31, 2010 8:52 PM, "solaristica01" <solaristica01@...> wrote:
> I figured out what it is I believe. I need to have just one output cable
from the AN1X, since M-Audio Fast Track is mono. I unhooked one of the sides
just to see what happens and the signal became much stronger, and normal...
> That did it. Why? Like I said, I believe it is because the fasttrack only
sees mono, but maybe there is some other hidden reason there...
> Thanks for answering to me though.
> Happy New Year!
instruments
use
>> n a t e
interface if
synth.
so
>> > Thanks very much.
>> > V.
2011-01-21 by jody
--- In AN1x-list@yahoogroups.com, "solaristica01" <solaristica01@...> wrote:
> I figured out what it is I believe. I need to have just one output cable from the AN1X, since M-Audio Fast Track is mono. I unhooked one of the sides just to see what happens and the signal became much stronger, and normal...
> That did it. Why? Like I said, I believe it is because the fasttrack only sees mono, but maybe there is some other hidden reason there...
> Happy New Year!
> > n a t e
> > > Thanks very much.
> > > V.
